Drag Racing Tech
Tranny brake question
Old Jun 6, 2014 | 10:59 PM
renthalatvr's Avatar
Default Tranny brake question
I'm running a 1998 Pontiac trans am with a th400 with a tranny brake ... My question is after I do my burn out and stage I hit the button and let off the foot brake and the car will move forward and the stop I then can push on the gas ... Anyone hear or this ?
Old Jun 7, 2014 | 06:29 AM
Old Geezer's Avatar
Try raising the idle a bit, B4 you engage the line loc..
Old Jun 7, 2014 | 06:33 AM
Ill try it today
Old Jun 7, 2014 | 08:42 AM
ZHAWK154's Avatar
Once you push the Transbrake button the car should stay put. Then when you get on the 2-step it may rock a bit but it'll keEp same staging position.
Old Jun 7, 2014 | 09:37 AM
Mine don't ... After I push the button and let off the brake it wants to move/jump and then it stops
Old Jun 7, 2014 | 01:15 PM
droksformula's Avatar
Try holding the button longer before you let off the brake tranny might not be at full line pressure yet.
Old Jun 7, 2014 | 02:11 PM
Ok I'll try thank u
Old Jun 8, 2014 | 01:38 PM
the higher rpms worked went up to 2000 rpms and didn't move
Old Jun 9, 2014 | 08:23 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
TH400 brake typically is better off with a bit more RPM to get pump pressures and fluid flow to move. The 400 has to fill a large capacity piston servo to apply the band that locks the drum... somewhat different than other transmissions.
Old Jun 9, 2014 | 08:51 AM
RENE'S RAGE's Avatar
Do you have a 2 step?
Or you just revving it up to 2 grand?
What size stall?
Old Jun 9, 2014 | 12:35 PM
ragtopz28's Avatar
Mine used to do the same thing (Rossler 350)...try cycling button 2-3 time, then hold down all while 'standing' on the brake. Solved my rocking.
Old Jun 9, 2014 | 08:58 PM
rene's rage I have a 2 step .. with a 4000 stall ... ill be changing to a 4800 with different gears
