Drag Racing Tech
Prototype 2 Step, who's interested??
Old Nov 17, 2001 | 06:51 PM
y2khawk's Avatar
Default Prototype 2 Step, who's interested??
I've been working on a 2 step for track use, trying to get some boost on the line.
So, I figured i'd make a little clip to show how it's coming along.
Here's a 1 minute video of the 2 step in action. It's just the prototype right now, so don't mind the wiring mess <img src="images/icons/smile.gif" border="0">
I'm limmiting at 3200 for all of this, and w/ the exhaust capped. My neighbors hate me if i do this w/ the cut outs open and at 5000 <img src="images/icons/grin.gif" border="0">
I first show from the engine bay, show where the connections are made to the coils using OEM connectors. I'm trying to do it such that all you do is plug it in, and run your trigger line.
the i have the camera on the ground in front so you get a better idea of how much the turbos are spooling.
then inside. Watching the tach and then the boost gauge. It just starts to make boost w/ the exhaust capped. Open it up, and i make about 2 psi at 3200 <img src="images/icons/smile.gif" border="0">
higher than that and i make good boost for sitting still
http://harlan.sketchy.net/store/2step/2step.mpg
it's about 14 megs, sorry <img src="images/icons/smile.gif" border="0">
[ November 17, 2001: Message edited by: y2khawk ]
[ November 17, 2001: Message edited by: y2khawk ]</p>
Old Nov 17, 2001 | 06:57 PM
NoOne's Avatar
Default Re: Prototype 2 Step, who's interested??
Your cable modem is broke <img src="images/icons/smile.gif" border="0">
Mediaone's gonna come chop off your pee pee for hosting that from home.
Old Nov 17, 2001 | 07:04 PM
Colonel's Avatar
ME ME ME ME MEEEEEEEEEEEEE!!! I NEED a two-step BAD!
Old Nov 17, 2001 | 07:10 PM
y2khawk's Avatar
[quote]Originally posted by NoOne:
<strong>Your cable modem is broke <img src="images/icons/smile.gif" border="0">
Mediaone's gonna come chop off your pee pee for hosting that from home.</strong><hr></blockquote>
LOL, it's comcast <img src="images/icons/smile.gif" border="0">
my normal server is having DNS issues so i can't log in to FTP it up <img src="images/icons/frown.gif" border="0">
so, i'm working on it <img src="images/icons/smile.gif" border="0">
Sorry for the slow *** downloads
Old Nov 17, 2001 | 08:04 PM
y2khawk's Avatar
ok, it's on the way to the fast server <img src="images/icons/smile.gif" border="0">
Old Nov 18, 2001 | 10:46 AM
GeorgeC's Avatar
Harlan, as a bracket racer who's considering the switch to electronics, you 2-step would be a blessing. There's no other way I'd consistantly be able to launch my car off a t-brake. The lack of a 2-step is one reason I haven't made the switch already...
Please keep everyone here up to date (especially me <img src="images/icons/wink.gif" border="0"> <img src="images/icons/wink.gif" border="0"> ). Then maybe I can buy that delay box and tranny brake I've been wanting! <img src="images/icons/grin.gif" border="0">
Old Nov 18, 2001 | 11:49 AM
Colonel's Avatar
Looks to work fine in the video. <img src="images/icons/cool.gif" border="0">
...So, when can you send me one? <img src="images/icons/smile.gif" border="0">
Old Nov 18, 2001 | 11:59 AM
y2khawk's Avatar
[quote]Originally posted by Colonel:
<strong>...So, when can you send me one? <img src="images/icons/smile.gif" border="0"> </strong><hr></blockquote>
once i figure out what the coil pack connectors are gonna cost me i'll know the details. I know people are not gonna want to cut and splice 8 coil pack wires <img src="images/icons/smile.gif" border="0">
those are the biggest issue i have right now. Getting one-sies and two-sies of the is not problem, but 50 or 60 gets tough <img src="images/icons/smile.gif" border="0">
It does make for intersting backfires if you hit it while driving, good for tailgater's <img src="images/icons/grin.gif" border="0">
Old Nov 18, 2001 | 04:49 PM
Joe Kizzire's Avatar
Resident Grump
Are you using the existing rev limiter or have you designed a soft touch????
Old Nov 18, 2001 | 07:03 PM
y2khawk's Avatar
at this point is a single lower limiter, with the existing PCM limiter still intacked.
Although, it's a simple matter of making it a true 2 step. You could set the PCM limiter high, and have a soft touch come in lower.
All depends on what people are interested in <img src="images/icons/smile.gif" border="0">
I personally prefer ignition limiting vs fuel cutoff limiting. especially under boost or nitrous for that matter.
harlan
Old Nov 18, 2001 | 08:36 PM
ChrisB's Avatar
Will this work on a LT1? If so you can mark up one order (as long as it's under 75 or so bucks).
Chris Bennight
Old Nov 18, 2001 | 08:41 PM
steve's Avatar
put me on the list harlan...
you do have a list dont ya!!!
steve frank
[ November 19, 2001: Message edited by: steve ]</p>
Old Nov 18, 2001 | 08:47 PM
Big Mike's Avatar
That is so cool!! Can I use this on my M6 on spray off the line?
Old Nov 18, 2001 | 09:07 PM
NoOne's Avatar
M6's w/ N20 wouldn't benefit too much, its more for people with boosted applications or those like George, and I'm assuming here so correct me if I'm wrong, who are running a big stall and maybe hit a little too hard off the line or stall too much, this lets them launch on the gas but not up against the stall.
Right?
But for boosted applications it means a 6 speed car can make boost in neutral, which would turn those nice 1.7 60's into 1.5's or better assuming nothing breaks.. I guess it could also make an auto make boost under the stall speed.
Old Nov 18, 2001 | 09:31 PM
GeorgeC's Avatar
Well, my specific application would be for bracket racing. The two step would be used in conjunction with a t-brake and delay box, if I decide to run electronics races in the future. In my case, the 2-step would allow me to stage the car, press the t-brake button, and floor the gas while maintaining a "launch rpm" of whatever value (say 2800rpm). I wouldn't have to concentrate on keeping the rpms at a certain point, or hitting the gas at the right time, since it would already be WOT. It would reduce the heat buildup in the converter as well, since I wouldn't be on the converter as hard at a lower rpm.
For a super/turbocharged car, it would allow them to build positive boost at the starting line (especially helpful with manual tranny car).
Old Nov 19, 2001 | 12:05 AM
Cmarsh93z's Avatar
I have a question, is it possible within the ECM programming to link an action (such as the clutch switch being depressed) to lower the rev limit. I know on some of the DCM cars, they can do that. Just curious!
Chris
Old Nov 19, 2001 | 12:07 AM
blackhawk2000's Avatar
We were talking about hooking it up to the clutch release switch.
Old Nov 19, 2001 | 12:22 AM
y2khawk's Avatar
[quote]Originally posted by blackhawk2000:
<strong>We were talking about hooking it up to the clutch release switch.</strong><hr></blockquote>
i had originally set it up to work on 2 inputs. One to put it in "standby" kinda like a get ready state. That was to be the clutch switch. Then another switch to arm it. That would have been just another pushbutton.
so push in the clutch and then push the other button. It stutters until you release the clutch, or push the arm button again. But, w/ the many apps out there, i figured go w/ a single trigger input.
I have a latching relay setup that will do just what you need. clutch in, hit the button, it stutters until you dump it <img src="images/icons/grin.gif" border="0">
then BAM, wheels up or break something <img src="images/icons/wink.gif" border="0">
Old Nov 19, 2001 | 11:50 AM
NoOne's Avatar
George,
For some reason I got you mixed up with the other George w/ the 9 second Lt1 <img src="images/icons/grin.gif" border="0">
then I saw your sig in another thread...oops...
Old Nov 19, 2001 | 01:22 PM
[quote]Originally posted by IndyZ28:
<strong>Anyway, can I be on the so-called "list"?</strong><hr></blockquote>
Why don't you just scam one from the man? <img src="images/icons/wink.gif" border="0">
I want one for those pesky tailgaters! <img src="images/icons/grin.gif" border="0">
