Guess my ET............
Its full weight, full interior.
150 TNT wet shot out of the whole?
Then a 150 wet shot out of the hole and then a progressively controlled 150 DP shot coming on shortly after?
2 reasons...
1. You will probably be racing at Moroso... lol
2. Your full weight and full interior, will be tough to get in the 9's
I personally would leave the car just as it is, that setup you have is one sweet street rod.
Also forgot to mention... you said assuming a good hook.. hrmm 436ci + 150 shot off the line...gunna need have your suspension and tires dialed in.
Lee
this also assumes a good drag racing driver.
ideally 9.90s should be easy in the internet world. i would say shoot for 10.50s as is. and pray those sleaves hold on.
Your thinking maybe 10.50's on motor as is?
Or with the 150 shot?
Chris
Gotta drive it for 800 miles, then have it dyno tuned with the wet shot.
If I was smart I would just keep the bitch on the street like I planned. I'll definitely give it a couple runs on motor. Maybe I'll have the 150 wet shot come in 2nd gear or something like that.
I went 11.02 with my old ARE 422ci iron block a few years ago at 3550 raceweight. I've seen a number of big cube street cars go 10.8-11.2's.
It's better for street/highway runs which is what you bought it for right.The 150 is going to be a simple matter of practice. Don't panic, don't stress, take your time and the 4L60E will last because vig still isn't going to get it on the juice.
Look for 10.4 spinning at 133mph run if you get 6-10 runs on the gas for the night.Is the car really faster than these predicted speeds??? Yes... but it's simple practice, tire pressure, shock tune, finding the launch RPMs that gets you just enough wheel spin and suspension tuning which takes some time. The faster times will come.
Rick
If I could do it all over again I would have run it longer on a 26 or a 27 and not gone to a 28. I might have also went to a 3.70 and pulled the 4.11's.
I should be able to do that on motor.
