Drag Racing Tech
Guess my ET............
Old May 24, 2004 | 08:05 PM
gator's 99TA's Avatar
3200 is great for a low peaking 436 super stroker. on nitrous is should work great as well
Old May 24, 2004 | 08:46 PM
02SOMWS6's Avatar
Originally Posted by MechMan
I say 11.2 @120 on the 150's with a 2.1 60' and a .950 r/t
By the end of this season I'll be running a 11.0-10.9 on a stock bottom end.He should be quicker than that.I hope for his sake.I would say with the right tranny and rear and slicks the car should run 10's on motor and 9's spraying.I would be very mad if it diddn't and I was him.I've gone 11.5 on my stock clutch launching at a soft 3800 rpm with a stock cat back.Once I blow my clutch I'm switching to spec stage 3i and will be launching at 4600 rpm, aand then a x-pipe to 3" duels and upgrading my stock fuel system with a 255lph fuel pump and fuel rails and maybe injectors.I know that if that isn't enough I'll do a BMR k-member and a-arms and a set of bogarts up front and be in the 10's on engine(stock bottom end) and 9's with a tnt 100 shot that will act like a 150 shot or better with my split duration cam and big valves.So if he dosent top me I would be pissed
Old May 25, 2004 | 12:27 AM
Quickin's Avatar
Thats cool. Just wondering what a car like this can do with practice.
I've been to the track 2 times when the car was 100% stock and 1,500 miles, so basically I have zero track experience.
We'll see soon enough. <-------in that order
Old May 25, 2004 | 12:30 AM
Quickin's Avatar
Originally Posted by Caveman
Get some Hoosier slicks and go to Bradenton, or come here to Olando on Fri June11 for Quick 32 test -tune, track prep will be great for the 200+MPH dragsters. Nice meeting you Lyle and i`ll probably see you at Mikes when you pick up your car. Good luck Dave
You to man I'll try to plan on sticking around for a couple nights, like Friday and Saturday, if I don't have to fly. I may have to just drive up and pick it up and leave.
Old May 25, 2004 | 09:01 PM
02SOMWS6's Avatar
I'll be at orlando speedway in september if you need some one with some knowhow behind the wheel.Would love to make a 9 second pass during vacation
Old May 28, 2004 | 12:15 AM
Quickin's Avatar
I got no problem letting ya take her down the track. I suppose with an auto, if it dead hooks outta the hole with slicks and with the hammer dropped, there's really nothing more to do but go for the ride, right?
I don't have a cage so I'll have to run some 8th mile passes for practice, then do an all out run. I guess if I hook during any of the 8th mile passes I should just say "fugg-it" and keep going.
