Drag Racing Tech
Just got back from the track
Old Sep 6, 2014 | 08:16 PM
mcmuscle3's Avatar
Default Just got back from the track
Hey guys, well I am a in-experienced drag racer. before today I had only been down the track twice in 2 different cars. Today I finally got to fun my 2000 Formula M6, with LT's and Slp lid... Managed some decent times in my opinion, my fastest run was 13.89 @103mph with a 2.2 60ft. Of course street tires, and man I tell you they would not grip ...... I managed a few 14.00s and 14.1s as well with trap speeds of 104. after 4 runs my rear end started making a poping noise anytime I turned. But IDC because my ford 9" is almost built
Let me know some helpful hints or just comment good or bad on my times
Old Sep 6, 2014 | 08:22 PM
HCI2000SS's Avatar
Trap seems low
Old Sep 6, 2014 | 11:46 PM
mcmuscle3's Avatar
thats all she had:/ gave it to the floor and redline in 3rd gear... I have one step colder plugs for my nitrous, but I didnt have my bottle filled. Idk if plugs would make much of a difference though. what should I be trapping?
Old Sep 7, 2014 | 07:12 PM
HCI2000SS's Avatar
108-110 mph would be more like it
Old Sep 8, 2014 | 11:48 AM
mcmuscle3's Avatar
geez, would that be because of my bad 60ft or what i wonder?
Old Sep 8, 2014 | 04:25 PM
Bitemark46's Avatar
Running in late August/early September I'm sure the air wasn't helping any. In the summer you will run the slowest. In the cooler months you car makes the most power and will yield the best times.
Being your are on street tires you can't shock the drivetrain. Try and preload the clutch (where it almost moves the car). This will help reduce the hit.
When I used to run radials I used to air them down to like 20psi or so. Disconnecting the front swaybar also helps weight transfer. With practice and what I mentioned you should be able to get down to the 2.0 or high 1.9 range.
-Mark
Old Sep 8, 2014 | 05:01 PM
mcmuscle3's Avatar
ha, thank you for the useful info!
Old Sep 8, 2014 | 05:19 PM
HCI2000SS's Avatar
OP is your car tuned?
Old Sep 8, 2014 | 05:31 PM
madmike9396's Avatar
really need some MT et drag radials !
trap does seem low for a long tube car.
im sure more seat time will yield better times as well.
Old Sep 8, 2014 | 06:10 PM
scotty2000ss's Avatar
I had the same mods as you at one time. Best time was 13.4 @ 109. Maybe shift a little earlier? Lowering my tire psi helped me also.
Old Sep 8, 2014 | 06:19 PM
mcmuscle3's Avatar
well bristol TN THunder Valley is considered a "slow track" based on what the drag racers say... My car is untuned.
Old Sep 8, 2014 | 08:05 PM
my second time at the track
Old Sep 9, 2014 | 05:43 AM
That last run was nice. Good run!
Old Sep 9, 2014 | 07:20 PM
mcmuscle3's Avatar
nice!!! so today while i was trying to figure out where to mount my wot switch for nitrous i found out that my floor mat kept my gas pedal from going WOT by about a 3/4". lol
Old Sep 10, 2014 | 03:43 PM
That should help with those trap speeds
