Questions about airbags? (suspension)
First off, is there a particular brand that everyone is using, or is there a bunch out there? Where can I get them? This is probably a dumb question, but do you install both airbags or just the one in the passenger side? Does this affect your 60 ft. times at all? How hard is the install? Thanks.
Airlift summit or jegs i run both with seperate lines most of the time at the track put more in right side on street let some out of both sides i have run up to 25 psi in r side mostly 5 and 15 at track 2 and 8 on street also roll bag up as tight as pos. put cover back on stem it will stay compressed .will slip in put line out bottom of spring. most mount valves thrue top of license plate (looking at plate the valves will be sticking thrue the lip above the plate ) easy to adjust and not seen a a glance hope this helps
