Drag Racing Tech
A few friendly pointers on using ET Streets
Old Dec 6, 2001 | 06:09 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default A few friendly pointers on using ET Streets
If you have never used ET Streets here are some friendly tips, guys jump in....
1) Never drive in the rain unless you have to. I typically can't go over 30mph in the rain. On occasion I have been able to get up to 50mph. But if you hit some water you will kick out the rear before you can even react. So don't go over 30mph in the rain. I have driven 50 miles in rain once. I can feel the back kicking out.
2) Always get a little water on the tires at the track, your posi will thank you.
3) HEY I was doing my burnout and my car was starting to go sideways. That means they are hooking. <img src="images/icons/smile.gif" border="0">
4) How much PSI say for 16" et streets? I'd never go below 16 and higher than 22 on the track.
Old Dec 6, 2001 | 06:17 PM
Slow Z28's Avatar
Default Re: A few friendly pointers on using ET Streets
good topic John. and great info. now what about psi recommendations for 15" tires?
Chris
Old Dec 6, 2001 | 06:26 PM
Bob Cosby's Avatar
[quote]3) HEY I was doing my burnout and my car was starting to go sideways. That means they are hooking. <hr></blockquote>
Or your posi is getting old, and spinning one tire with more torque than the other.
[quote]) How much PSI say for 16" et streets? I'd never go below 16 and higher than 22 on the track.
<hr></blockquote>
As high as possible and still get traction. If I had to go as low as 10-12 psi to get traction, I'd do it in a heartbeat. <img src="images/icons/smile.gif" border="0">
Old Dec 6, 2001 | 06:30 PM
MysticZ28's Avatar
Just got some Hoosier QTPs, haven't had 'em to the track yet. Would you apply the same rules vis-a-vis tire pressure? Number 1 goes without saying.
Old Dec 6, 2001 | 06:39 PM
minty's Avatar
dont drive on them as a daily driver, some of them arent DOT approved and you can get a ticket or the car towed.....also, i wouldnt drive around town doing launches at every light......thats like doing a dry burnout....BYE BYE REAREND>.....
Old Dec 6, 2001 | 07:42 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
15s I would say are the same psi. I have 15s and I run 16 psi and hook good. Hell my ets still look brand new <img src="images/icons/grin.gif" border="0"> .
Old Dec 6, 2001 | 07:55 PM
Jim98WS6's Avatar
[quote]Originally posted by Pro Stock John:
<strong>If you have never used ET Streets here are some friendly tips, guys jump in....
4) How much PSI say for 16" et streets? I'd never go below 16 and higher than 22 on the track.</strong><hr></blockquote>
5) Be careful where you drive. Those tires are VERY soft and cannot be patched. I actually had a small rock push it's way through an ET Street one time (brand new tire too <img src="images/icons/frown.gif" border="0"> )
Old Dec 6, 2001 | 08:34 PM
Mike Hoffpauir's Avatar
If your car gets sideways on the burnout use more water! I dont agree with you that this is an indication of traction John. Ive had my car walk on me during the burnout, i say fack it, make the pass and spin. The next pass i'll use more water and have a better run =)
Old Dec 6, 2001 | 08:58 PM
McRat's Avatar
Spinning to one side means one tire didn't get wet enough. Roll into the water and spin 1/2 second, then roll just out of the water.
Mark the tire with shoe polish where the valve stem goes. Check after each pass. If the tire moves on the rim DO NOT lower the pressure any more.
Johns right, water is scary, even a little rain is dangerous.
If you run wide tires on the front, keep the inflation pressure high on the rears for street use, like 32psi. Lower the fronts to the same.
If all your dash lights come on, don't sweat. The ABS freaked out because Streets are bigger than your front tires.
[ December 06, 2001: Message edited by: McRat ]</p>
Old Dec 6, 2001 | 09:47 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
[quote]Originally posted by McRat:
<strong>Roll into the water and spin 1/2 second, then roll just out of the water.</strong><hr></blockquote>
Why must people insist on doing this?!?!?!!!! <img src="graemlins/gr_images/icons/mad.gif" border="0" alt="[very mad]" />
Think about it. When you park in the water hole and spin your rear tires, what happens? Water gets slung all underneath your wheel wells. What happens to the water in the wheel wells then??????? It drips BACK ON YOUR TIRES. Result? You spin off the line.
Also getting sideways while doing a burnout is a result of not enough rpms at the wheels. Stick guys should try to dump it in 2nd and get the rpms up there. Auto guys should try to shift into 2nd(starting in 1st) after your rpms are up there. More tire speed is better for the burnout.
Tim
Old Dec 7, 2001 | 12:18 AM
Colonel's Avatar
I just blip the throttle very quickly just to barely spin the tire over one round.
This way I don't spin water up into the wheel wells (I agree, bad idea) but I do get %100 water coverage on the tires which makes for an easier burnout.
I have seen some people just back into the water box and then pull straight out again and end up with only half the tire surfaces wet. This sometimes makes for a clumsy burnout. This is of course more common with a narrow water box or one that isn't as full as it should be.
Old Dec 7, 2001 | 01:42 AM
JordonMusser's Avatar
I ran never more than 11.. mor like 10.5psi in my 16" ET streets. only way I could get my lowered/autoX setup 6spd hooptie to 1.4 60ft.
Old Dec 7, 2001 | 03:24 AM
SSValet's Avatar
As far as patching goes, my friend had a screw go thru his, and Discount patched it up.
Right in the center of the tire.
I was positive that they wouldn't because of the tire composition, but they did it.
No probs whatsoever so far.
I run 15 lbs at the track.
Old Dec 7, 2001 | 10:18 AM
LS1Tech Co-Founder
[quote]Originally posted by Colonel:
<strong>I just blip the throttle very quickly just to barely spin the tire over one revolution.
This is pretty key IMO. If you get unequal water on the tires, like say NO water on one, you will get one tire fire.
Good points on going sideways, yeah that can absolutely mean the posi is dying.
I want to stress again how dangerous it is to drive in the rain on ET Streets. If you try to be a hero and go say 45mph in rain, you will not be able to correct fast enuff if the car spins out.
When you start going really low on tire pressure you run the risk of having the tires cup and really maybe you need to look at the car (if the track is hooking for others). I've seen people bitch about cutting a 1.7 at one of our private track rentals and I am like whoa dude the guy after you cut a 1.52 <img src="images/icons/smile.gif" border="0"> .
Old Dec 7, 2001 | 02:54 PM
McRat's Avatar
[quote]Originally posted by Tim98TA:
<strong>
Tim</strong><hr></blockquote>
You're right, it's more like a "Blip" I've never really timed it. Like Stephen said, I just spin enough to get water ALL around both tires. Seldom do I see more than a light coat water in the box at our track. I do NOT drag water down the track. I hook better with wet burnouts than dry, so water dripping probably isn't happening.
If you are running stock hydraulics on a stock clutch, be careful about 2nd gear heating. You may spin the clutch instead of the tires. Been there, done that. 4.10's and aftermarket clutches may not have the problem.
About the "not enough RPM" theory to sideways burnouts, I never start my burnout at less than 5000, but when there is not enough water in the box is when I get sideways. So I do know that not getting both tires equally wet will always cause walking.
Old Dec 7, 2001 | 03:20 PM
Tim98TA's Avatar
Course all the POS tracks we have here, the box is more like a lake, so I simply back in, pull out like 10-15 feet and burn out at 5000 rpm for about 4-5 seconds.
Tim
Old Dec 7, 2001 | 08:15 PM
timelord's Avatar
PSJ!! Why don't you just switch at the track,that is what I do,you really appreciate it 140 miles from home when it's raining.+ even on dry you musn't be able to push into the triple digits for long or in curves???
Old Dec 8, 2001 | 01:32 PM
Jim98WS6's Avatar
[quote]Originally posted by SSValet:
<strong>As far as patching goes, my friend had a screw go thru his, and Discount patched it up.
I run 15 lbs at the track.</strong><hr></blockquote>
Actually I had mine patched too but the tire guy said that as thin as they are the heat from a burnout would go through the tire and cause the patch to lift off. I ran tubes after that and never had a problem. On the other tire, I too picked up a screw and didn't even try to get that one patched - just added a tube to that side.
About driving in the rain. I got caught in a rainstorm on I25 between Denver and Fort Collins after racing one night. The rearend was all over the place even at 30mph. I finally ended up driving on the shoulder till the next exit and sat at Wendy's for about 3 hours waiting for the rain to stop and the roads to dry. It was unbelievable how much I was sliding around.
-Jim
