Drag Racing Tech
Skinnies??? Questions.
Old Dec 11, 2001 | 08:40 PM
MysticZ28's Avatar
Default Skinnies??? Questions.
First, which or is there a 15" wheel that will fit on the LS1 front without having to grind the brake caliper?
And if there is which size - 15x4, 15x31/2 or 15x5??
I'm looking at the Weld Pro Stars, Center Line Convo Pro and the Center Line Auto Drag.
Any and all input is appreciated ... Thanks, Mike
Old Dec 11, 2001 | 09:26 PM
98TAauto's Avatar
Default Re: Skinnies??? Questions.
15x3.5 weld draglites along with a spacer and you dont have to grind anything up front... that is what mostly everyone runs... however no matter what you will have to grind the rear for 15's to fit....
Old Dec 11, 2001 | 11:14 PM
Slow Z28's Avatar
yep, i just went through this process...
15x3.5" rim w/ 1.75" backspacing w/ 5/16" spacer and 12mm x 1.5" long shank lug nuts
that's what i have and hope this helps.
Chris
Old Dec 12, 2001 | 08:28 PM
MysticZ28's Avatar
It's helped a lot ... Thanks guys. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
