hooking up with stock power (auto) ...
The only other thing I would recommend is Lower control arms and relocation brackets. For factory cars experiencing wheel hop or traction issues, we find the LCA and LCA Relo Brackets make a huge difference!
Shoot me an email or call the shop and I'd be happy to help as much as possible!
that's the size I have on stock 16"z28 5 spokes (ET street drag radials)
traction is harder to find on asphalt vs prepped concrete, at the track you will be fine.
I also do not like to preload like your describing but rather flash the convertor from idle with the front sway bar removed which transfers weight to the rear more quickly planting the tires so they can hook
with an auto car on a tire/suspension capable of dead hooking the car the higher you can get the convertor in rpm's as abruptly as possible the higher in rpms it will be able to achieve before the drivetrain is all loaded and the convertor is done doing its job.
if you are up at 1500 rpm against the brakes on a stock convertor which I assume is what you have theres no room left in the rpm window of that convertor for it to do what a convertor is designed to do "flash" up in rpms closer to where the engine makes good power . By quickly/abruptly getting rpms to go up you can get the convertor to achieve higher rpms than if the rise in rpms were less abrupt.
The other benefit of doing it this way is all that extra rpm's you achieve through flashing can shock the suspension and abruptly push the weight bias to the rear tires which is where you want all the weight to plant the rear tires and hook up well , as you get into more power and higher stall convertors you may need to change from what I am describing to be able to find traction , on a stockish setup on a quality drag radial on a decently prepped track it should full on hook allowing you to use this artificially high launch prm for current convertor "flashing".....
between purchasing the right tires the first time and getting this method down you will likely find yourself beating ls1 cars with more mods than you at the track , learn to couple a good 60 foot with a good reaction time and most people you race will be playing catch up , if they have more power and marginal traction instinct is to push down harder on the gas likely causing excessive wheelspin - the race is over usually at that point lol
I have ran a few sets of the MT ET street radial on a 72 nova that I bracket race. (255/60-15"). The tires do great at the track but I can still spin them easily on the street. I don't street race so it is the perfect tire for me. If you do a lot of street driving something with a harder compound may be better for you.
Last season I ran the Nitto 555r on my camaro. And while I have hit low 1.6's it is more of a street tire than drag radial. And it does great for what it is understanding it's limitations. Drives great on the street even in rain, long lasting, but just when you need it most it will let you down at the track. Well it does me. (Disclaimer - my front suspension is stock and after the initial weight transfer the front will fall back down. On a marginal track I blow the tires off). This coming season I hope to switch to the MT street radials.
Good luck, and the bottom line is to have fun.
Plus, I am a firm believer that DR's need heat cycled the first time. I carried a new set to the track one time, it was the worst traction I have ever had, while everyone else was hooking decent.
Al
I tried several tire pressure settings but the rears did best at 22 psi.
I staged and loaded to around 1100 rpm.
When I launched I didn't punch it to the floor, I just quickly put the pedal to the floor.
For the burnout I heated the tires up slightly and did a 1 or 2 dry launches before staging.
This track was very well prepped so that plays into it too. As far as the street my car smokes the tires with no hopes of hooking.
My car has kooks headers and duals, slp cold air, tune, bmr Panhard, tunnel brace, and lcas. So not a lot of $$$ in mods.
... sounds like i'll be giving you a call!
