Drag Racing Tech
Racestar New Beadlocks
Old Feb 8, 2015 | 09:41 PM
mgood613's Avatar
Default Racestar New Beadlocks
Has anyone tried the new beadlocks that racestar has out on a 4th Gen F-Body? I was wondering how they fit? They call for a 7" backspace and 38mm offset( PT# number 92-597253 DP).
The standard 15x10 racestar pt# 92-510254 DP fit fine, but they are a 7.25 backspace with 46mm offset.
Any opinions?
Thanks,
Old Feb 9, 2015 | 08:18 AM
4SFEDSS's Avatar
Im interested as well since ive been waiting over a month for a set of standard rears from summit. I was gonna have them sent directly to champion for a single beadlock installed, but for a few hundred more I could just get these in a double beadlock.
Old Feb 9, 2015 | 08:55 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
Any opinions?
Thanks,
The Racestar wheels are quite heavy to begin with and you want to add a set of bead locks?
Most people that actually need a bead lock wheel would go with a lighter wheel like a Weld Alumastar, RT-S, or Steet Lite and Comp5 from Billet.
I will almost guarantee that your car will slow down when you put those wheels on. If your purpose is looks, then so be it.
Rise of the Phoenix's Avatar
Maybe Prostock John will come in here and help answer the question. He is a Race Star dealer.
Old Feb 9, 2015 | 09:52 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
They won't be available until late March until they get the first shipment in.
Old Feb 9, 2015 | 10:04 AM
Zmg00camaross's Avatar
What Eric said. Heavy *****!! Be no purpose besides looks and IMO there is awesome looking wheels that are way lighter and beadlocked. But would be cool to see some.
Old Feb 9, 2015 | 10:18 AM
4SFEDSS's Avatar
I don't know of any that clear factory brakes, definetly not a double beadlock anyways.
Old Feb 9, 2015 | 12:15 PM
I would imagine your correct. My thought is someone that needs a beadlock would be a pretty serious car.
Old Feb 9, 2015 | 02:23 PM
Mikey 97Z M6's Avatar
I'd say any stick shift car running a slick in the bottom 11's or quicker will require rim screws or bead locks. Mine started slipping at around 13psi running 11.30's with a 1.6x 60 foot.
Auto cars can get away with running quicker without them because they don't shock the tires nearly as hard.
Old Feb 9, 2015 | 03:11 PM
I glued mine and been good so far at 1.4x 60ft have this internal battle if I would look dumb with beadlocks going low 10s high 9s. Not that I care but you know.
Old Feb 9, 2015 | 03:57 PM
93camaro_zzz's Avatar
I agree that racestars are really heavy wheels. Also, I have been 1.36 on glued Prostars. I am sure there have been those that have went even quicker than that even.
Old Feb 9, 2015 | 05:33 PM
mgood613's Avatar
Thanks for all the good info.
I might just stick with my glued setup I have now.
Old Feb 10, 2015 | 09:05 AM
Dark SS's Avatar
As far as I know race stars are right on par with weld RT-S weight wise.
Old Feb 10, 2015 | 09:28 AM
4SFEDSS's Avatar
I don't necessarily "need" beadlocks but I don't care for screws, so im going to settle and have an outer beadlock done.
Old Feb 10, 2015 | 11:58 AM
ssvert99's Avatar
Billet Specialties has the Street Lite wheel in f-body specific available with beadlocks. USA made(Chicago area), not China. Cost will be a bit moire sure, but the reduced weight and high quality is well worth it, not to mention supporting USA manufacturing.
http://www.billetspecialties.com/whe...ngle-beadlock/
Old Feb 10, 2015 | 01:26 PM
BIGsmokey10's Avatar
My billet specialties are at mac fab getting double bead locks . They are kick *** to work with and the turn around time is the same week
Old Feb 22, 2015 | 11:14 PM
ponyhater27's Avatar
Tubes or no tubes?
Old Feb 23, 2015 | 07:18 AM
Originally Posted by ponyhater27
Tubes or no tubes?
No tubes.
Old Feb 23, 2015 | 07:16 PM
No tubes.
Thanks! Im trying to decide if Im going to glue or use screws. Im going to run a 28x11.5 Hoosier QTP on a 10" darkstar with tubes.
Old Feb 24, 2015 | 11:40 AM
Guitar's Avatar
If you're using tubes. SCREWS. You do NOT want them to accidentally rotate on the rim with tubes.
