Drag Racing Tech
Roll racing Tire selection
Old Mar 12, 2015 | 08:57 PM
93camaro_zzz's Avatar
That's the tire I use. I love it! But I am thinking if I wanted a roll race tire, I might have looked at something big like a 325/50. If you can fit them that is.
Old Mar 12, 2015 | 09:08 PM
oscs's Avatar
Why is that? Also these are a dual purpose tire for me. I actually like the height. It should help me utilize my lower gears a little better.
Old Mar 13, 2015 | 10:09 AM
T6Rocket's Avatar
But seriously, take as much rear camber out as possible with an alignment. I can see the negative camber even in that tiny pic!
Even if you can only get 1 deg out, it will help a lot with straight line traction. Of course, the toe will need adjusted as well, but a good alignment guy will know what to do.
Al
Old Mar 13, 2015 | 10:55 AM
oscs's Avatar
Al
Yeah it is -1.8 in the rear right now. I have an appointment to straighten up the rears next week.
Old Mar 16, 2015 | 09:59 AM
oscs's Avatar
Does anyone have any experience with these PRO tires? I have a little less than an inch clearance between the inner fender and tire. I'm pretty sure if they rubbed i would cut a tire as the contact would be confined to a single "sharp' spot on the fender that cannot be easily removed. Anyone seen these grow?
Old Mar 19, 2015 | 01:43 PM
willizm's Avatar
They shouldn't grow at all being a radial and I have probably less than an inch clearance all the way around on them. IIRC they are slightly taller than 28"'s. I believe they are 28.2 to be exact, but like I said. It's tight on my car but i've not had issues with rubbing. I also have a pretty stiff suspension setup on the rear so it doesn't squat.
Old Mar 31, 2015 | 03:43 PM
T6Rocket's Avatar
How did your car do at the roll racing? Looks like it was hauling ***!
I saw a partial video of the car, and noticed it had regular M/T's on it.
Al
Old Mar 15, 2016 | 10:59 PM
exquisit's Avatar
how did you go with roll racing with 15s?
does it get sketchy?
