Drag Racing Tech
Roll racing Tire selection
Old Mar 9, 2015 | 01:50 PM
oscs's Avatar
Default Roll racing Tire selection
Seeking advise from any of you that "roll race" on prepped conditions. Im debating on a dedicated set of tires for the TX2K15 roll race event. I am currently running 315/40/17 NT05r tires and they don't like the street one bit.. I mean 100MPH 4th gear *** end getting a little loose type ****. However 3rd/4th gear when heated up stick fine on the track, well at 16.5lbs anyways..
So my question is this.. Stick with the 17" NT05r tires or look into the Mickey Thompson ET street bias ply tire. I hear the biased ply will generally be a little slower but if they allow me to ramp all 21-25lbs in over say 1.5sec over my current 2.5sec than the difference might be beneficial. Also i have a pair of 16" wheels lying around so what ever tire i select will be a 16r
Anyone with extensive tire experience in a light car making a lot of power please chime in.
Old Mar 10, 2015 | 11:50 AM
99peweterls1's Avatar
I wouldn't mix bias ply's on the back of the car with radials up front especially with the territory this event comes with. Your best bet would be a fresh set of radials, Mickey Thompson or Hoosier.
How wide is the 16" wheel?
Old Mar 10, 2015 | 12:02 PM
oscs's Avatar
Originally Posted by 99peweterls1
I wouldn't mix bias ply's on the back of the car with radials up front especially with the territory this event comes with. Your best bet would be a fresh set of radials, Mickey Thompson or Hoosier. How wide is the 16" wheel?
I figured with a set of ET streets (BP) Instead of drags i might be ok. I know they are both biased ply but not sure if the exact differences. 16" rim is 8" wide. Are the NT05r that bad of a tire? They got great reviews when i was looking and seem to hook up fine on the track. What im trying to avoid is buying another set of DR.. I cant see the MT ET street radial being THAT much better than the NT05r Radial, well not from a roll anyways on a prepped surface. I could be wrong though.
Old Mar 10, 2015 | 12:26 PM
HCI2000SS's Avatar
What kind of power are you making to spin those NT05R's like that at 100 mph lol?
Old Mar 10, 2015 | 12:51 PM
oscs's Avatar
Originally Posted by hci2000ss
what kind of power are you making to spin those nt05r's like that at 100 mph lol?
+/- 1000whp @ 3200lbs with me in the car.
Old Mar 10, 2015 | 01:23 PM
HCI2000SS's Avatar
That would definitely explain it lol. From everything I've seen the MT is the best when it comes to traction. Of course they don't last long but it's hard to have the best of both worlds
Old Mar 10, 2015 | 01:49 PM
willizm's Avatar
If you can get some 15" wheels on the rear i'd go with the MT Pro radials. Its what I run and they are really sticky. Even more so sticky than the MT ET radials i had previously.
Old Mar 10, 2015 | 02:24 PM
oscs's Avatar
What size wheel do you have them on?
Old Mar 10, 2015 | 02:25 PM
oscs's Avatar
Yeah I keep reading MT is the way to go. It's funny though becuase when I was doing my research I couldn't find a single bad thing about the NT05r.. Guess I wasn't looking hard enough.
Old Mar 10, 2015 | 04:19 PM
Per mickey thompson's chart the e/t street radials are already a pretty soft compound. The pro radial would be nice but it is for a 15" wheel and it's a 28 compared to your short sub 26" tire your currently running.
A fresh set of e/t street radials or Hoosiers on that 16" wheel goes a long way over what your running now. Given your limited options, that's what I'd go with over the 17" wheel to get some sidewall back there.
Old Mar 10, 2015 | 05:19 PM
oscs's Avatar
Per mickey thompson's chart the e/t street radials are already a pretty soft compound. The pro radial would be nice but it is for a 15" wheel and it's a 28 compared to your short sub 26" tire your currently running. A fresh set of e/t street radials or Hoosiers on that 16" wheel goes a long way over what your running now. Given your limited options, that's what I'd go with over the 17" wheel to get some sidewall back there.
Where I agree I just can't get over the idea of buying a set of ET street biased ply for the 16" wheels and keeping what I got for street/roll racing.. What I don't want to do is end up buying another set of radials and kicking my self in the *** when I want to hit the drag strip later. The biased ply would obviously be a better tire for that. I think I'm going to just hit the track on Friday and see how these tires hold in 3rd/4th gear @1K.. Last track visit was around 700 and they worked fine.
Old Mar 10, 2015 | 06:59 PM
I agree with the bias ply being the better tire at the track, but especially on your car, it's going to be tuff getting the narrow 17" wheel to hook. Mickey Thompson/Hoosier > Nto5r
Old Mar 11, 2015 | 07:35 AM
T6Rocket's Avatar
The only radial that has a chance of hooking 1000 WHP is the M/T DR Pro, but it only comes in 275/60-15, and is 28" tall. You really need a 10" rim to hook that power.
For a manual transmission, some stiff wall M/T ET Drags in the back and bias ply skinnies in the front will cover both drag and roll racing. Any of these other lesser options are just "steps", and in the end you will just keep buying different tires.
With radials and a manual trans, you run a great risk of wheel hop, especially the 17" size that is on there now. What rear diff is in the car? Not the original 280Z diff I hope.
Al
Old Mar 11, 2015 | 08:01 AM
oscs's Avatar
Al
Yup this is what bothers me the most. Problem with the ET drags are they are not DOT legal and for some of these races i need them to be. Im doing my hardest to get a 15" rim on the car. If i can i will probably run the Radial 28" Pro.
The diff is a VLSD Q45 diff with beefed up everything.. Well the diff is stock but they are stout.
Old Mar 11, 2015 | 03:52 PM
T6Rocket's Avatar
Take as much camber as possible out of the rear alignment settings for straight line traction. You probably won't get it all the way to "0" since the car looks lowered, unless they make adjustable control arms.
Al
Old Mar 11, 2015 | 04:53 PM
oscs's Avatar
I said **** it.. Ordered up some Weld RTS 15X9 wheels with some 275/60/15 MT ET street PRO X275 tires..
Old Mar 12, 2015 | 08:50 AM
T6Rocket's Avatar
For roll racing, you could get away with a little higher tire pressures for stability like 25 psi. From a standing stop, I would not go over 16-17 psi, to limit the chance of wheelhop.
Hopefully you won't have an issue with the PRO's not being DOT legal.
Al
Old Mar 12, 2015 | 09:42 AM
oscs's Avatar
For roll racing, you could get away with a little higher tire pressures for stability like 25 psi. From a standing stop, I would not go over 16-17 psi, to limit the chance of wheelhop. Hopefully you won't have an issue with the PRO's not being DOT legal. Al
They are DOT legal. They say not for road use (track only) but they carry the DOT stamp of approval.
Old Mar 12, 2015 | 02:49 PM
T6Rocket's Avatar
Okay, cool. Everyone I know that has used them, loved them! They will wrinkle on the launch.
Al
Old Mar 12, 2015 | 03:14 PM
oscs's Avatar
Okay, cool. Everyone I know that has used them, loved them! They will wrinkle on the launch. Al
That's good! I need a little wrinkle on the launch with this 6spd. Hoping the have the radial characteristics up top. I need them stable at 170+MPH
