Drag Racing Tech
Lithium Battery
Old Mar 29, 2015 | 03:51 PM
transampetews6's Avatar
Default Lithium Battery
Has anyone here have a lithium battery? Any cons?
Here's is the one I'm thinking of buying http://shoraipower.com/lfx36a3-bs12-p126
Old Mar 29, 2015 | 05:12 PM
01ssreda4's Avatar
Only one guy I know on here runs lithium and he says he likes it. I chose this AGM instead.
Old Apr 2, 2015 | 09:36 AM
slow trap's Avatar
i bought a parts store lithium battery and am very happy with it so far. had it for 6 months or so. fires up my 408 easily and holds charge. only drive my car once in a blue moon but it has worked great so far.
Old Apr 2, 2015 | 09:01 PM
That's kinda what I wanted to hear. Thanks for the feed back. Did you buy a special charger for it too.
Old Apr 2, 2015 | 09:10 PM
Guitar's Avatar
I got the Shorai attached and situated in the car to run at least temporarily, still need to get a hold down for it. However, drove the car around town then to and from work today with AC and stereo (I have aftermarket headunit + amps + sub) and it did fine. Voltage stayed normal, even in traffic car was fine. Starts up quick as ever, so far so good. I'm not entirely convinced in the long term with this battery, but we'll see how she does. I haven't got the charger yet and am unsure if I will or not.
Old Apr 3, 2015 | 06:14 AM
Sounds like you're daily driving your car more than I will. I'm definitely buying the charger.
Old Apr 3, 2015 | 08:24 AM
Mike Morris's Avatar
I do so does Hiosilver and Big Hammer
Old Apr 4, 2015 | 06:41 PM
redbird555's Avatar
I run that same battery as well. Starts up mine every day to DD I even run a small sound system in mine
Old Apr 5, 2015 | 09:02 AM
Seems like a no brainier. Remove my 40lb. Optima red top and install a 5lb. Shoraipower lithium. The battery in my work truck just died. I'll just move the Optima into the truck.
Old Apr 6, 2015 | 08:39 AM
HioSSilver's Avatar
I've been running that battery for 2 years......even through the winter.
Old Apr 6, 2015 | 04:47 PM
Guitar's Avatar
Do you have the charger for it?
Old Apr 6, 2015 | 05:20 PM
HioSSilver's Avatar
yea I have a charger.....I don't use it though.
Old Apr 7, 2015 | 05:10 AM
TTur1996's Avatar
The thing I don't understand on these Lithium Batteries is, you use the same alternator to charge and keep charged in the vehicle. But you can't use the same charger out of the vehicle. What is different? Does not make sense. If someone could explain it, that would be great.
Old Apr 7, 2015 | 07:02 AM
redbird555's Avatar
You can use a normal charger it just has to be on 2 amps. An alternator will shut off to keep the battery from overcharging. Lithiums are very sensitive to that. so you can use a small charger just be sure to monitor it very carefully.
Old Apr 7, 2015 | 09:02 AM
That's the thing. Not over charging it. The charger they sell charges at a lower power and shuts off so it doesn't over charge. I'm getting the charger because I know one day I'll forget and over charge it and then I'm into it for another battery.
Old Apr 7, 2015 | 10:34 AM
01ssreda4's Avatar
Alternators charge at way more then 2 amps so I dont see the issue.
Old Apr 7, 2015 | 10:42 AM
slow trap's Avatar
never had a charging issue with it so i haven't bought a special charger. i may screw it up but have no plans on wasting money on a SPECIAL charger. just as stated ,don't overcharge it. probably the same people telling other people they need a special charger are the same ones selling them .... just my $.02
Old Apr 18, 2015 | 07:23 PM
zssman's Avatar
Excellent information here guys. Any pics off the mounted battery setups. Thanks.
Old Apr 19, 2015 | 02:39 PM
HioSSilver's Avatar
Here's how I mounted mine. I used the oe battery bolt hole on one side and put a 5/16 nut plate in the other side.
Old Apr 19, 2015 | 05:02 PM
redbird555's Avatar
I'll see if I can get some pics of mine but basically I made a strap out of aluminum that wraps around the battery and bolts into the factory hold down threads
