Will a 28 x 14.5-15 fit in a wolfe mini tub with modification?
I have a wolf minitub and want a wider tire. 98 Camaro.
Has anyone used this tire with a wolfe minitub? Could it fit with modification?
Moving LCA inward?
Hoosier qtp specs
Tire Size:28 x 14.50-15
Wheel Diameter:15 in.
Sidewall Style:Solid white letters
Tire Construction:Bias-ply
Tire Diameter:28.00 in.
Section Width:13.10 in.
Tread Width:12.00 in.
Minimum Recommended Wheel Width:10.00 in.
Maximum Recommended Wheel Width:12.00 in.
Moving LCA inward?
Hoosier qtp specs
Moving LCA inward?
Hoosier qtp specs
Moving LCA inward?
Hoosier qtp specs
A 14.5 section width will fit.
14.5 tread width will not because of the section width would be too wide.
