Suspension advice
The springs and shocks are
Strange single adjustable coilover w/ 275lb springs
Front shock is set a 3 clicks from full loose
Strange double adjustable rear shocks w/ 93-97 v6 springs
Rear compression is 3 clicks from full tight and extension is 5 clicks from tight
Rear Lca are in lowest hole possibly on the rear axle
MWC anti-roll bar
-3* pinion angle
Tires are Hoosier drag radials 17lbs of air
Here is a video in slow motion, at the end as the car begins to come down you can see the gap between car and track surface disappear.
If I tighten the rear compression completely wouldn't that cause the car to rotate up even more?
I may be misunderstanding your first part about tire spin. Why would I want the tires to spin earlier? I don't want the tire to spin at all.
You have to have some weight transfer to stick the tire at the hit, but too much transfer is not gaining you any forward motion. The more firm front extension will slow the weight transfer and keep the nose from rising quite so fast, but at some point this may cause the tires to loose grip earlier in the run if you slow the transfer too much.
Move the lowers up one hole and tighten up the front shock extension a bit. Leave the rear shocks alone until you see what this does.
Same recommendations here. I would tighten the rebound on the front shocks and bring the lca's up a hole, or tighten the rear rebound also if you have adjustable rear shocks
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
