Drag Racing Tech
need help with window, pulling stock wiring
Old Jun 14, 2015 | 12:48 PM
mike13's Avatar
Default need help with window, pulling stock wiring
I've gone to a aftermarket ecu and pulled most of the factory wiring. Still have the wiring in the door. How do I wire the switch to get the drivers side window to work?
Can I just wire in a power and ground to the switch?
Old Jul 3, 2015 | 09:08 AM
FasTimeSS's Avatar
This I would also like to know? Anybody please help out with this?
Thnaks
Old Jul 3, 2015 | 07:04 PM
JL ws-6's Avatar
Race your car!
A dpdt switch, with the window motor attached to the center lugs, and power out to the outer 4'lugs configured so that opposite polarity is on to each of the outer sides will allow a simple dpdt switch to operate the window. No relays, nothing fancy. Just fuse the power to the switch, 10-15 amp fuse shouldn't pop. Dpdt switches are available everywhere just get one that's rated for 20 amps
