What is your best 60ft in a 6sd with stock rear,4.10's,and DR?
Re: What is your best 60ft in a 6sd with stock rear,4.10's,and DR?
A previous setup I had:
stock rear with 3.73 gears
Mcleod single clutch (kevlar/organic disk)
Nitto Drag radials 275/40/17 on 17x9" WS6 rims
MTI Stage 2 heads, T1 cam, LS1 intake
3695 lbs raceweight
Best 60' = 1.72
Average 60' = 1.78
I would hold the rpm between 3500-4000 rpm and slip the clutch out carefully, while trying to maintain the constant rpm between that window. Once the car felt like the tires were grabbing and the rear squatted, I would let the clutch all the way out and floor it. Training myself not to floor it immediately was the hardest part.
Here is a video from 2 years ago, 11.92 @ 117 mph with a 1.75 60' time on 275/40/17 Nittos @ 22 psi
11.92 @ 117 video
You can hear the clutch slipping out when I take off. Yes, its hard on the clutch, but great on the timeslip! Takes some practice for sure, pretty challenging to run quick on radials.
Tony
3695 lbs raceweight
Best 60' = 1.72
Average 60' = 1.78
11.92 @ 117 video
Tony
1.68, BFG's
had a lower 60 ft on my 11 sec pass but the timing equipment didnt' show it on my slip ;(, i thik it was a 1.62 or so...
Technique is in my sig, launching tips
Nitin Reddy
[ February 11, 2002: Message edited by: Ws6Luvr ]</p>
Nitin Reddy
