What size wheel studs for track use?
What size do I need that will stick out as they should based off track requirments and what are the best?
My car is a 99 z28 ls1 camaro
Obviously a 5/8" stud is best in the rear, but not sure if you're wanting to go through that. 1/2" studs in the front is fine.
Summit has a ton of options for this, anything you want really, just have to search by thread you need.
What did you mean that the ARP stud would not fit your rear end?
All the studs I have now are thread in type so no more press in, last 2 rear ends I put in I had the longer studs in the axles when I ordered it so there would be no need to change until the 5/8 are needed, and I had the axles done with the holes for 5/8 also in the flange so they could upgrade with just a stud purchase. No machining needed on the axles.
We prefer to sell rear ends with 1/2 screw in studs because they are stronger than the 12mm studs an factory wheels will still work you just have to purchase new lug nuts.
