Oil pressure drops to 35psi on hard launches but rises in park while stationary
If I free Rev the engine the pressure goes up accordingly, but on hard launches and 30 rolls, the oil pressure drops down to 35psi..
things I changed from when this wasn't an issue.
Earls oil cooler -10AN lines, swapped from 10w40 to 20w50 (45-48 psi idle, 217F oil)
any suggestions? Stock ls1 pan already has improved racing baffle mod.
oil pump is a melling high volume with the stock spring in it. (car didn't do this before on 20w50 either, it's the same oil pump from the old motor)
...or try this: http://www.improvedracing.com/oil-pa...ffle-p-30.html
LS1Tech Sponsor
Which Melling pump are you using specifically, the 10296 or the 10355?
Thanks for looking into my oiling issue,
I checked my dipstick again this morning, it was a quart low, so I added another quart and all is well now. Transbrake launches and rolling starts don't starve the motor of oil anymore
