Project "WTFail Trans Am"
Once we pull a bit more out of her we will get her on a scale.
Now to clean up the inside. Time to strip down the wiring harness, and get this thing looking good. Trying to decide if we want to put any interior back in or not. I personally would like to get some lightweight carpet in there and put the lightened up panels back in. Figure the whole interior would be under 100lbs. Inycoddjobz wants to keep it a tin can with a zip tied cluster haha.
I've always wanted to take a bone stock 6 speed car and do a full suspension setup with a good clutch, a set of 4.56s or 4.30s out back and some 28x10.5 slicks and give her hell. I mean stock to the paper air filter.
Also going to pick up a short torque arm, and coil overs/shocks. Thinking about Vikings for the front and comp or strange for the rear?
1) Paint and Install HVAC Delete Panel
2) Install Water Pump "U" Hose( As well as flush coolant because it is apparently green and dexcool too...awesome....)
3) Remove Front Sway Bar and Mounts
4) Remove Front and Rear Bumper Supports
5) Remove Door Panels and Speakers
6) Remove Driver Airbag
Once this is done, it should be on the road to going back together, kind of. Next session will be a wiring harness attack. The car will either end up with a nice cleaned up harness, or on fire....who knows.
The car is gutted, and will remain this way essentially. Keeping exterior lights, gauges, power windows, locks(may as well since BCM is staying probably), hatch release, OBD port, and 1 cigarette lighter(tuner request). Other than that, I want the wiring gone.
Inycoddjobz took the car for a spin today, apparently the speedo, tach, and gas gauge do not work; but the oil press and coolant temp do. I am going to try to track this.
Since the BCM is deleted, the large connector going to the BCM serves no purpose, as it is connected to nothing. Correct? Can I just cut all the wires, trace them to where they go and de-pin them?(Exception being the yel/blk starter relay wire which I am going to ground)
BCM is going. Just a little confused about the fuel pump relay thing?
