Project "WTFail Trans Am"
The car is a 1999 Trans Am A4 owned practically since birth by a middle aged woman. Mechanically the car was flawless, and bone stock. Cosmetically.....well it was owned by a middle aged woman. There is more clear base paint than there is clear coat, from years of sun abuse. And I think there are more scratches than paint. Lets consider that weight reduction.
Isn't the best fitting aftermarket WS6 hood I have ever seen....I can practically change the headlight without opening the hood. Well anyway, after checking the car out Inyczoddjobz decided he had to have it.
And so it began....
Edit: Remember I said I can practically fit my hand between the headlight/hood gap? I actually can apparently.
Next thing I know, I cut a speaker wire....and the car won't run anymore? I know I didn't mess up....So I decided to take the night off and start fresh the next day.
And by start fresh the next day I mean unbolt some more ****.
You know when you pay a professional company to install your new fancy aftermarket alarm? Well what they actually do is electronically rape your car. Inycoddjobz and I spent hours tracking down the entire interior harness of the car because of this. They cut and taped, not spliced...actually cut wires, twisted them and taped, the entire system in. Accessory cable in the column, cut in half, wires going to BCM cut in half, you get the picture.
What actually happened when I cut that speaker wire was when they cut some of the BCM wires, they replaced the factory wiring with speaker cable and tucked it away.....
Anyway, street car problems we want a race car so not our problem.
Oh yea...and these.
Strange S60
-Spool
-4.56 Gears(Getting swapped out)
-Strange 35 Spline Axles
Wolfe Drag Bar
Strange Drag Brakes
BMR Panhard Bar
BMR LCA's
BMR Cross Member
Freddy Brown Built TH400 w/ T Brake and RMVB
Driveshaft
I believe the next order of business is going to be:
Remove Heater Core
Remove AC System
Remove AIR
Remove EGR
Remove Front Sway Bar
Remove Driver Air Bag
Fix Headlight Motor
Remove Door Speakers
Remove Wiper Assembly
Remove Under Trays
Remove Inner Fender Liners
I will see if I can knock most of this out this week hopefully. Waiting for parts stinks =[
Today came a bunch of goodies to get going with.
TSP 1 7/8" Headers
TSP OR-Y
SLP Lid
SLP Bellow
KN Filter
SLP Loud Mouth I
I have previously had the experience of an SLP with LT's back in 05/06 when I thought it would be a good idea...But it wasn't. Inycoddjobz wanted to learn first hand, I am sure we will end up with a Dyno bullet in there or a set of True Duals sometime in the future ahha.
I am hoping the car will be in the 11's from the crap we just stockpiled. If it's not I am going to light it on fire. For some weight reduction of course.
Anyway, If Inycoddjobz can pilot this thing to an 11.70-11.50 I am hoping to spray it to a 10.0....The car should hopefully be VERY light and cut some good short times with some adjusting.
Viking Double Adjustable Coil Overs(300lbs)
Rear Shocks-Not sure yet, recommendations?
Torque Arm- Crossmember mounted, short style, recommendations?
Change Rear Gear- 3.73 I am assuming
Wheels/Tires- Car will be on a 275/50
Remove Drive Airbag
Remove HVAC
Remove AC
Remove Front Swaybar
Remove Door Panels
Remove Under Trays
Remove Drive Airbag
Remove HVAC
Remove AC
Remove Door Panels
Remove Under Trays
Burkhart Chassis has very nice stuff. Check out there website.
You will want a anti roll bar also.
Single adjustable shocks for the rear is sufficient. Vikings are good.
Not sure if you will need it but, we got 350lb springs on the front, and its just barely enough.
