440ci with a 600 shot @3900lbs = ? ET
Hell, I hope its faster than 10.7's which I read on the posted thread...I have a mild 382 stroker MTI built with X1 cam, stg 2 LS1 heads, and small headers in a HEAVY car...3550 for the car and 417 lbs for lil' ol me! So I am at 4,000 lbs with full tank, and I was running 11.6 on radials....Auto, 2800 stall, 3.23 10 bolt, stock style suspension. 1.68 short time on radials.
Now I have torque arm, bigger fuel system, M&H tires on 16 X 8.5 Welds, no front sway bar, built tranny, Vig 3400 multi-disc, and half way through installing NX MAF wet nitrous kit. I figure with the 150 shot I will be low 10's, and with 200-250 shot possibly high 9's. SHould be running low 11's on motor and good tires with better converter now as compared to last year.
I certainly hope with a 440 cube with either AFR 225's or C5R heads, the car would be good for low to mid 10's easily and a 200 hp shot should knock about a second off that. If this thing doesn't run 8's, even with not so great suspension, I would be pissed.
I bet for the money he spent on this thing, he could have just gone to LPE and got a pretty nasty TT Vette that would dip into the 8's on good tires!!!! ANd sounded/looked stock! But, to each his own.
Originally Posted by gator's 99TA
hmm i also would like to see a 3900 lbs car need wheelie bars! ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Mike
Location: From the Bowels of Hell!!! You want some of me bitch?!?!?!
1 Post
Originally Posted by V6 Bird
Go look for the 3900lb ARE car that went pretty damn fast on stock suspension. Mike
Originally Posted by Tim98TA
What car of ARE's weighs 3900lbs and went 8's or near?
How about you, what does your car run?
Mike
There's a very simple solution that would put all this to rest......Get that bitch to the track and see what it runs. I don't care if it has 2000hp and weighs 2000lbs. Until it(or any car) runs the time it's just another nice car. There are alot of cars out there with gobs of power that run shitty times.
I beleive it was a LT1 convertible car. Orange and white if i remember correctly. i think they built the motor. Im not sure that it ran 8's but i know it was in the 9's somewhere.
Mike
Mike
#33
1 Post
Originally Posted by badboy4life
where is the mass air meter? I just have never seen one with out one.
#36
Just In Case Any One Cares Nick Scavo Has Gone 8.7s In A 4200lb 65 Impala On A 10.5 Tire In Nsca Fastes Street Car Class Over 5 Years Ago AND 8.4S AT3800 LB FROM CHITOWN ITS AFAST TIMES CAR 440 CI ON SPRAY FUEL INJ
#37
1 Post
#39
Motorboater
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
