HAL shocks = faster ETs?
If my car is already hooking hard enough ( I don't need more traction ) then how would HAL adjustable shocks (up front) make me quicker? I understand they're for more weight transfer, but you only want more weight transfer for more traction... right or wrong?
Actaullt I never seen an actual gain in my 60 foot time but it made it WAY more consistant instead of my 60 foot time being all over the place.
mmiller, what 60 fts are you pulling? What tires are you useing? Do you still have the front swaybar connected?
I am running 26" x 11.5" x 15" ET Streets on 15" x 10" Pro-Stars with an air bag, subframes, tubular LCA's, front sway bar removed, 1LE rear sway bar w/urethane end links and bushings, stock torque arm w/poly bushing, and stock pan hard bar. I have cut a best 60 ft. of 1.51. For me, the HALS showed no improvement in my 60 ft.
<strong>Colonel,
I am running 26" x 11.5" x 15" ET Streets on 15" x 10" Pro-Stars with an air bag, subframes, tubular LCA's, front sway bar removed, 1LE rear sway bar w/urethane end links and bushings, stock torque arm w/poly bushing, and stock pan hard bar. I have cut a best 60 ft. of 1.51. For me, the HALS showed no improvement in my 60 ft.</strong><hr></blockquote>
I also meant to ask if you're spinning the tires? I assumed that you were since you are surprised that your 60ft did not improve. Otherwise, no improvement makes sense. Also, what PSI are you running in the air bag?
<img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
mmiller - The Hals will help on the tracks that don't hook as well, but at HRP I definitely wouldn't have expected a gain with them considering the 60' times you were pulling w/ the stock shocks in place. Your suspension would have to be JACKED UP to unload at HRP! Sticky tracks are awesome, and you can get away with a lot more at a very well-prepped track and sticky tires. Just look at John's 1.38 60' time on 26" tires with STOCK suspension! <img src="gr_eek2.gif" border="0">
[ March 02, 2002: Message edited by: Trevor D ]</p>
