Drag Racing Tech
Guys running 10's, post your RWHP numbers and raceweight
Old 06-10-2004, 03:22 PM
FEAR THE LS1's Avatar
Originally Posted by JS
FEAR,I have right around 385RW threw an unlocked 4L60E.Thats right around what your unlocked # were w/the TH400.I guess I have a good shot at hitting 10's on motor if I get some good air and get down to about 3400lbs.FWIW,my car 60fts in the 1.45 to 1.53 range depending on the track prep.I still need a adj. rear sway bar.
That sounds about right. What stall are you running? 3400 is a decent raceweight, if you could do any mods to lighten up the hotrod some more it would help. Everything on mine is light weight, from the battery to the suspension to the interior, light weight carpet etc. If you can go from 3400 to 3300 your talking about a whole tenth in the 1/4 mile. It might make the difference from an 11.00 to a 10.90 run etc.
Nytmare: I always refer to race weight as the weight with me in the car on the scale at the track. I always go by the weight of the car as it goes down the track.
Lee
Old 06-10-2004, 06:34 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Originally Posted by Nytmare
Is that raceweight with you guys in the car ?
3200 is the weight with me in the Hot Rod on the scale at the track.
Coach
Old 06-11-2004, 12:46 PM
Moderator
LIL SS's Avatar
Originally Posted by 383LQ4SS
3525 race weight
on the 100 shot (510 rwhp) single stage 10.48 at 131 with a 1.44 sixty foot
this is on a 6 speed
Allen,
You have set a goal for me
Old 06-12-2004, 01:12 PM
JZ'sTA's Avatar
Yes that is why it is raceweight.
Raceweight includes everything right down to the 30 lb nitrous boddle some of us use.
BTW when my car was as heavy as a pig, weighing just over 3500 lbs and I add a extra 200 I ran 10.7's at 129-130 and only dynoed 525 running a little juice.
Also while only making 360 RWHP all motor I went 11.7.
This is with a 3600 Yank and 4L60E.
Old 06-14-2004, 08:32 PM
BLK02WS6's Avatar
I'm nowhere near 3200lbs,More like 3550lbs and I dynoed 410/399 but looking at FEARS times I think with proper hook,weather I might have a small shot at hitting 10.99 but more realistically I'll be right in the low 11's.
My 224 H/C setup isnt all that bad.
I could add more cam and add another 10RW,throw a lsx/90 mm tb for an additional 15 and be right around 435RW threw an A4.
JS,
Sounds like I'm right with you - I'm at 3,600 headed for a minimum of 3475 when I finish my weight mods. I was hoping for 10's on motor too, but don't think I'm gonna make it. We are going to try another converter soon to get my 60's in the 1.4's, but I don't think I'm gonna make it without porting my heads.
I decided I'm not gonna spend any more money (after the weight mods) to try and make it on motor - if I don't get it this fall, I'll break out the bottle.
Old 06-15-2004, 01:07 AM
770Guy's Avatar
I have a 396 stroker, every suspension mod you can get, just put a TH400 in it, transbrake, the whole 9 yards. still cant break into the 10s.
Old 06-15-2004, 07:43 AM
Whats your race weight?
Old 06-15-2004, 08:30 AM
770Guy's Avatar
3500lbs
Old 06-15-2004, 08:38 AM
Something is not right with your set up. At 3500 lbs you should be in the 10's no problem.
Give us more info on your set up Please.
Coach
Old 06-15-2004, 09:46 AM
JS
JS's Avatar
Coach is right,at 3500lbs 500RW should bust a 10....
Whats your 60ft,1/8 et and mph and your 1/4 et and mph.
Old 06-15-2004, 10:01 AM
kp
kp's Avatar
3520lbs here, last dyno was 441rwhp unlocked, ran a 10.96 @ 124 (1.54) at ~300' DA.
With a 50 dry shot shutting it off at 5900rpm and shifting at 6500 I ran 10.74 @ 125 at 2000' DA
Old 06-15-2004, 11:20 AM
  #32
770Guy's Avatar
60ft is 1.39 , 1/8th is 7.15 @ 95 , the last run in the 1/4 was 11.15ish, but we ran out of gear about 20 feet before the traps, just went down to a 4.10 gear from a 4.30. This weekend ill have new quarter times, if it doesnt break 10s we are gonna be disapointed.
Old 06-15-2004, 11:28 AM
  #33
770Guy's Avatar
This is the setup as it was when we were strugglin for low 11s. We just added a spool with 4.10s and the Strange Lightweight brakes, and 1 lightweight non adjustable racing seat.
Setup is as follows:
!ac
!front sway bar
396 Stroker
Strange 12 bolt 4.30s (now a spool with 4.10s)
TCI TH400 B&M Ratchet Shifter
TCI4400Stall
Transbrake
BMR 32mm Drag sway bar
BMR Xtreme Duty Torque Arm
BMR Adjustable tubular Lower Control Arms
BMR Lightweight K-member
QA1 shocks (front and back)
BMR adjustable Panhard Rod
Bogarts with 28.5 Hoosiers out back and skinnies up front
BMR subframe connectors
I think thats about it, probably something I left out.
Old 06-15-2004, 12:12 PM
  #34
A 1.39 60ft and you ran a 7.15 @ 95 mph. I cut high 1.4's and run 6.90's at 98 mph with a stock LS1 motor with the T-Rex cam. Something seems to be wrong with your set up. With the 4.30 gears I would say that you need a 29.5 to a 30 inch tire so you don't hit the rev limiter. You will be better off with the 4.10's and the 28 inch tall slicks.
What is your rev limiter set at?
What rpm are you shifting at?
What rpm are you leaving off the tranz-brake?
Coach
Old 06-15-2004, 03:58 PM
  #35
770Guy's Avatar
Coach
Limiter is set at 7,000
shifting at 6800
leaving at around 5000 with tranzbrake
Old 06-15-2004, 04:06 PM
  #36
770Guy's Avatar
And about the 60 foot thing, thats what me and my dad have been trying to figure out. How in the hell can we be pullin 1.39 60 foot times and still not be gettin atleast 6.90s in the 1/8th. I dunno if you saw my post in the Dyno section or not, but with the 6speed we made 504 and after we put the TH400 in we only made 420rwhp so we lost 84rwhp with the TH400, but gained about 40 rwtq
Old 06-15-2004, 04:35 PM
  #37
More info on the convert/trans set up please. We need to help ya figure this out, brother. My Dad and I have been right where you are. If I can help, let me know.
Coach
Old 06-15-2004, 04:38 PM
  #38
770Guy's Avatar
Coach
I dont know all the details, Ill have to ask my dad when he calls. We are running out of gear so thats probably why we arent in the 10s, but the 1/8th mile times make no sense at all. TCI told us the only thing they could suspect is that they sent the wrong converter and asked us to take it out and send it to them.
Old 06-15-2004, 04:48 PM
  #39
IMO, Running out of gear in the 1/4 didn't hurt the 1/8 mile times. I have alot of 1/8 mile data and Even when I was running 11.20's in the 1/4, I ran high 7.0's to very low 7.teens in the 1/8.
We need to know about the convert and trans set up to help ya out.
Coach
Old 06-15-2004, 04:52 PM
  #40
770Guy's Avatar
Coach
What exactly do you need to know about the tranny and converter? All I know off the top of my head is its at 4400TCi converter and a TCI TH400
