aftermarket steering column options
http://www.summitracing.com/parts/up...sfBhoCngjw_wcB
Or mount a 3 way switch
The MWC column kit is designed to be used with a aftermarket lower shaft, however we can set it up to be used with a standard 3/4" smooth bore, 3/4 DD style, or any other spline if need be.
I had DMC make me one when he was a sponsor on here, not a difficult thing to make if you have any fab ability you likely could do it with any of the above mentioned kits.
Or if you don't want to be bothered, above options are for sure fine.
Racer tip: If you are going to do one with a removable steering wheel, make the steering column short and get one of the wheel spacers to go on between the wheel and the quick release, it will make getting in/out of the car a lot easier.
