Drag Racing Tech
Fuel setups?
Old Dec 15, 2015 | 09:38 AM
mshadow's Avatar
Default Fuel setups?
For those of you who have built street/strip cars any advice on which route you took? or would take if you did it over?
Currently im looking at 3 options
Fuel Cell
Sumped 98 Tank
Intake setup
Intake has me worried about running out of pump long term on E85 and having to redo everything.
Old Dec 15, 2015 | 09:49 AM
cdubbzz's Avatar
I did a Squash dual in tank setup. They offer twin Walbro 450's for gas/E85
Old Dec 17, 2015 | 05:49 PM
willizm's Avatar
That will be my next set of pumps
Old Dec 18, 2015 | 01:44 AM
Blown06's Avatar
8 Second Truck Club
Anything I build that makes good power will either get a cell or sumped tank with an external pump.
For some reason I've just gotten away from the whole intank pump game.
My opinion is worth little, I don't build tons of cars......like a shop or anything.
Old Dec 19, 2015 | 06:43 PM
millerpa's Avatar
my street/strip combo.
areomotive belt drive pump
stock steel tank i sumped, capped off the filler neck and put charger terminals there and used a regular fuel cell lid and mounted it where the intake setup was.
Old Dec 20, 2015 | 11:07 AM
mshadow's Avatar
What sump did you use?
I'm leaning towards sumping my 98 tank or just getting the nasty tank.
Old Dec 20, 2015 | 04:38 PM
millerpa's Avatar
I just fabricated a sump and welded it to the 98 tank.
Old Dec 28, 2015 | 08:43 AM
transam69230's Avatar
Dual intank 255s ( I already had them), and sumped the plastic tank and using a MF 4303. The MF 4303 comes on with 4lbs of boost. I have finally maxed the pumps out on 26lbs making over 1350rwhp based on fuel consumption calculations.
The system runs -8 out of the factory hat, and Ys together with the 4303 by the rear-end and -10 feed and return.
