mods needed for a low 10s ls2?
10.28@129: 2000 Trans am at 3500 lbs race weight, 3.73 in 10 bolt, stock 4l60e with HD2 kit, stock aluminum drive shaft, 241 heads not milled and home ported, TV2 cam, LS6 intake, reworked vig stall by PTC, Nitrous outlet 185 hit, 93 pump gas.
10.09@133: same car at 3740 lbs due to added a foward manual valve body th400 when the 4l60e died, then killed the 10 bolt and put in a 9" with spool and 3.70 gear and 35 spline axles, steel PST driveshaft, went from 8" to 10" rear wheels, added a 6 point mild steel roll bar. Same motor setup as above but on a 250 hit with a splash of c16. The back seat and front leather seats stay in for racing. I only remove floor mats and rear divider.
The car went from 15 mpg with the 4l60e to 13 mpg with the th400 with no lock up.
