Need help regarding tires--->
OR should I run with a 27X11.5X15 QTP
Do u guys think the 4.10's and the short tire will casue me to not hook?I figure I'll be giving up alittle hook for the better rollout of the QTP?
26 VS 27???
And if I do keep the 26in Slick do u think I'll cross below 6800 on the it and 4.10 combo?
JS
Shifting at 6800, the 26"ers will have you going through the traps between 6400-6600. The 28x9's are going to cut you down to somewhere in between 6100-6300, but you should 60' much better or at least more consistently. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
BTW, my rpm guesstimates do not take converter slippage into consideration.
later, <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" />
Steve
the sides of my 1/4 panels?
I saw the pic of Fireballs car and the tire is millimeters away from the lip.Under tire growth I'd be scared it might rub?
Will the 28X9 fit?
JS
George/Steve whatta ya think too?
JS
I think you'll be fine <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Just dont go under 11psi in them IMO
Chris
I trapped 121mph no problem.
I had some sway at the big end, tires were at 11-12 psi which felt a bit low.
my vote, 28x9 slick <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I'm going with Hoosier 28x10x15s <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
George the T/A needs alot more work to fit a 28X10 since it has a body panel at the edge of the low 1/4 panel.
Fireball I agree I can buy adj. comtrol arms and center the wheel.Not a bad idea but I'm concerned about geometry.
I think 28x9 is the way to go.
JS
However, a lot of folks aren't interested or willing to do the clearancing to run a taller tire. I'm about to do some trimming to my bumper cover and see if I can fit something a little bigger than I have now...
1) Pinion angle
2) driveshaft length
I don't think shock angles change too drastically since they are fairly long
You can also pull that rear bumper cover back, but drilling a small hole in it, and using wire to pull it back, follow me? My buddy did it to clear the 28x11.5x15 ET Streets on his 99WS6.
Ask him @ chasgiv3@interaccess.com
