tubes or not with ET drags
Please any and all opinions and comments on your own setups are apreciated
Thanks!
With tubes it helps with keeping air in the tires. It also helps you to be more stable at the top end of the track with low tire psi. If you don't screw your slicks to the rims with tubes and your tires spin on the rim. You will cut off the valve steams.
Without tubes you have less rotational weight. Tubes are about 8 lbs each. If you put dish washing soap on the inside of the sidewalls before mounting them. They will not leak air.
Coach
1. More stability on the big end.
2. Some say they launch better but I never noticed.
3. Air stays in the tires. I have had slicks leak at the rim seal and also the side walls from.
Cons.
1. Heavier with tubes.
I have a set on the car with NO tubes and rim screwed.
I have another set I put tubes in because they leaked through the side walls. They are rim screwed also.
Good luck
When mounting I always clean all the crap off the bead area of the rim with alcohol to make sure it's good and clean. I then use Yamaha rim lube on the bead of the tire and then mount. The Yamalube stuff works as a lube when mounting but after mounting it acts like a glue.
I had some motorcycle drag racers tell me about the stuff and it's worked great for me so far as I've had zero tire slippage on the rim.
I will keep using this method until I notice some slippage. I just couldn't bring myself to drill these high dollar drag rims and will not do so until I start having problems with slippage.
TJ
Coach
I run my slicks at 10.5 or 11 psi and have no problems at the top end at all.
Coach
My old ET Streets would walk a lot. Part of this is caused by having a radial tire (165/15) up front. I'm running an ET Front now and shouldn't have near the problems....or at least I hope not.
I think you'll be OK without the tubes and screws for a while. Just mark the tires and rims and check for movement.
Rick
