Drag Racing Tech
Relocating rear lca inward, Fbody
Old Feb 6, 2016 | 02:28 PM
droksformula's Avatar
Default Relocating rear lca inward, Fbody
High all, I got new wheels and my tires are rubbing the offset lca slightly. Can I move the front of the control arm to the inside of the mounts without strength problems? I have bmr subframe connectors that ad quite a bit of steel over the factory box. Do you think this would be ok in hard 60fting car, 1.2s.
Here's a pic, this is with the old rim as now the tires are touching the lca.
https://i.imgur.com/1QWpd6N.jpg
Old Feb 9, 2016 | 06:29 AM
MADMAN's Avatar
LS1Tech Sponsor
I have a kit that allows you to do this. It requires welding but moves the lca up against the inner framerail.
Give us a call.
__________________
www.madmanandcoracing.com
225-343-9029
Old Feb 9, 2016 | 09:10 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
In order to move the LCAs more inboard than the inside LCA bracket will require shock relocation as well. inner mounted shocks require housing mounts, upper shock crossmember, and then a relocated fuel tank.
Old Feb 9, 2016 | 09:30 PM
Give us a call.
Thanks!
Old Feb 18, 2016 | 12:04 AM
DietCoke's Avatar
A certain fast blue LTwon car has his setup like this...
Old Feb 18, 2016 | 06:25 PM
Thanks for those pics, I guess that's what I'm going to do. Is that hollow bar that the bolt passes through welded inside that secondary frame rail?
