Drag Racing Tech
Where to start
Old Feb 11, 2016 | 03:05 PM
sarge130's Avatar
Default Where to start
I recently picked up a 98 TA auto with the intentions of making it a street/strip car with the ET goal of low 11's high 10's. Now this is my first GM car so my question is where should the smart money go? My heart says boost (turbo kit) heads exhaust and all the go fast goodies but my head says rear end drivetrain and suspension to handle all the power. So I guess I'm just trying to get some feedback and opinions from you guys that have been racing with this platform for years. Basically as the title says where do I start? or in other words where would you start if you had a clean slate?
Old Feb 11, 2016 | 03:27 PM
HCI2000SS's Avatar
How about we start with an initial budget lol
Old Feb 11, 2016 | 03:39 PM
sarge130's Avatar
Initially 3-4k
Old Feb 11, 2016 | 04:00 PM
HCI2000SS's Avatar
If my main goal was to break into the 10's, and all else was secondary, I'd build the rear first. The stock rear is probably not going to last running those times
Old Feb 11, 2016 | 04:06 PM
sarge130's Avatar
That's what I was thinking, the goals at the strip are the priority. The only reason I want to keep it street legal is to get back and forth to the track.
Old Feb 11, 2016 | 04:08 PM
nj02z's Avatar
Converter!!!!!!
I had 2 cars go in the 11's and never touched the motor. This put me in the 11s twice.
1- converter Yank 4000 SS
2- tires, (275/50/15 ) you can make all the power you want but who cares if you can't put it down .
3- exhaust (Tsp 1 7/8 headers and pick your catback)
Old Feb 11, 2016 | 04:12 PM
sarge130's Avatar
Originally Posted by nj02z
Converter!!!!!!
Were you running the 10 bolt?
Old Feb 11, 2016 | 04:20 PM
nj02z's Avatar
Yes but my wife's car just broke the pinion gear in November after it went 11.83 with mods listed. But sticking up for the 10 bolt it did have at least 300 passes on it and a best of 1.53 60' pulling the front wheel. Both cars now have a 9 in as we race every week sometimes twice a week.
Old Feb 11, 2016 | 04:25 PM
sarge130's Avatar
wow 300 passes I guess it's just hit or miss with them
Old Feb 11, 2016 | 04:29 PM
nj02z's Avatar
I use a solid pinion spacer not a crush collar. But this what it looked like when it let go. A good rear with everything that goes with it will shoot your budget right in the ***.
Old Feb 11, 2016 | 04:30 PM
sarge130's Avatar
Idk if I should be proactive, or just run it until weak link breaks then build it.
Old Feb 11, 2016 | 04:31 PM
sarge130's Avatar
I use a solid pinion spacer not a crush collar. A good rear with everything that goes with it will shoot your budget right in the ***.
The 3-4k is just for this year since I blew some savings buying the car. Gotta rebuild the TA fund.
Old Feb 11, 2016 | 04:34 PM
nj02z's Avatar
I would put a converter in it. Best bang for the buck.
Old Feb 11, 2016 | 04:35 PM
sarge130's Avatar
Ok I'll look into the one you recommended
Old Feb 11, 2016 | 06:59 PM
murphinator's Avatar
I agree with nj02z that stall is the best bang for the buck.
a4 cars survive pretty well through the 11's on a 7.5" 10 bolt , 6 speed car looking to race and work your way down to 10's rear would be top priority but I would stick with the 10 bolt until you are well into the 11's.
Real good bolt ons , sticky tires , stall and enough suspension mods to put that power down you should be into the 11's since your in CT and have excellent racing weather at several tracks around you - New England Dragway , Lebanon Valley , and real early and real late season atco in jersey are all tracks that get hero weather spring and fall so your mod dollar gets you more results if you pay close attention to density altitude before going to the track.
Where your eventual goal is 10's large primary long tube headers like 1&7/8 with true duals , cutouts ,or some other form of non restrictive sewer pipe lol
Fast intake w/ size matched TB
aggressive stall 4K or a bit higher since your stated priority is track times
aftermarket torque arm and relocation brackets for lower control arms
proper tune
and maybe a small shot of spray and you should be right where you want to be and right about on budget.
If you go heads cam you will need most of the stuff I listed anyways as "supporting mods" so you will also be in good shape for when you have more funds and want to cam or heads or both lol
Do you know if it has 273's or 323's for rear gears ?
Old Feb 11, 2016 | 07:17 PM
sarge130's Avatar
proper tune
Wow great info! Oh and i have 323s
Old Feb 26, 2016 | 03:38 PM
SteenH's Avatar
Adding to the already suggested!
Converter is a must, trans cooler as well.
Nice full exhaust system. If you can pick up an ls6 intake for the right price do it! A cam with a nice tune, some weight pulled and I'd be willing to bet you'd be pretty close to your goal best of luck
Old Feb 27, 2016 | 07:18 AM
sarge130's Avatar
wow that doesn't seem like that big of a list of mods to get to me goal. I'm kinda pumped that these motors don't need that much to get into the low 11's high 10's
Old Feb 27, 2016 | 07:58 AM
post #6 from nj02z is pretty much what you see the guys that have been through multiple 4th gens do , go aggressive with the stall , tires that will hook it , long tubes and I would suggest x pipe and true duals from there you will know how much more you need to do depending on how close you are to your goals.
If the car is more strip than street you may even consider going more aggressive with the stall , a bolt on car makes good power once you get the rpm's up and most convertors come with one free restall if you feel you went too far. Also its pretty common for people to go higher on the restall on a car that is slanted towards et's vs daily driving.
Old Feb 27, 2016 | 08:08 AM
sarge130's Avatar
ok yeah the car is going to be mostly strip, the only reason I'm keeping it street legal is because I need to be able to drive it to the track which is about 2hrs away since I don't have truck and trailer.
