Drag Racing Tech
Need Help Now!!!!!
Old Jun 13, 2004 | 10:16 PM
TWINK's Avatar
Default Need Help Now!!!!!
what would a N/A stock cubic inch LS1 auto with a trex cam, 4400 stall, 323 gear, ls6 intake with drags cutting a 1.6 60' run in the eighth and quarter? Would a 7.032@93 be reasonable? or would that have to be with nitrous? thanks for the help...
Last edited by TWINK; Jun 14, 2004 at 12:09 AM. Reason: i put some wrong info down on the post
Old Jun 13, 2004 | 10:28 PM
Black Z's Avatar
Originally Posted by TWINK
what would a 98 t/a auto with a trex cam, 4400 stall, 323 gear, ls6 intake with drags cutting a 1.6 60' run in the eighth and quarter? Would a 7.032@93 be reasonable? or would that have to be with nitrous? thanks for the help... he has nitrous and were trying to figure out if he sprayed or not
I seen a guy that had that same setup run a 7.05 at 95 with no nitrous at Redline Raceway in Texas.
Old Jun 13, 2004 | 10:52 PM
distortion_69's Avatar
7.0 sounds reasonable, IIRC thats approximately low low 11's or high 10's. That sounds like a max effort setup, but its doable. I hope to run similar numbers. I'm a little surprised that he ran that with a 1.6 60' tho.
Peace,
Josh
Old Jun 14, 2004 | 06:39 AM
TWINK's Avatar
TTT
Old Jun 14, 2004 | 07:15 AM
crainholio's Avatar
You might do better asking "I NEED COMPLETE GUESSWORK NOW!!" as that's about all you'll get.
Old Jun 14, 2004 | 02:30 PM
TWINK's Avatar
Ttt:p
Old Jun 14, 2004 | 02:34 PM
crainholio's Avatar
10.92sec @ 128mph.
Old Jun 14, 2004 | 06:41 PM
Scalpel's Avatar
What's the race weight, DA, etc?
Old Jun 16, 2004 | 01:06 PM
TWINK's Avatar
Levi this is something that you alex and saul were figuring up already get and answer to some conclusion's
Let's say full interior w A/C on...
Old Jun 16, 2004 | 01:37 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Anything is possible.
BUT, I have a N/A stock ls1 with ls6 intake. A3, T-Rex cam, 5.13 gears at 3200lbs. I cut high 1.4 60fts and run 6.9's to 7.0's @ 98 mph in the 1/8 mile and my car is a race car.
I sure would like to see the above car run those numbers.
Coach
Old Jun 16, 2004 | 02:46 PM
The Juggernaut's Avatar
I agree with coach
Old Jun 16, 2004 | 03:12 PM
Humanoid's Avatar
I have MTI X1 cam, Stage 2e heads,ss4000 stall on et streets. (some traction problems) 3550lbs race weight
1.69 -60'
7.59 -1/8
91.41 mph
