Drag Racing Tech
Twisted frame? can it be fixed?
Old Jun 13, 2004 | 11:50 PM
SUX2BU's Avatar
Default Twisted frame? can it be fixed?
i think my frame might be twisted a litte cause from behind my car looks crooked. i want to put some SFC on it but should i have the frame checked first or what?
I've been to the track alot and always launch at 6k on spray so that might have something to do with it.
Old Jun 14, 2004 | 12:16 AM
Lswonder's Avatar
can u bend a unibody?
Old Jun 14, 2004 | 02:39 AM
AL SS590 M6's Avatar
It's probably just the rear springs being un=.
Old Jun 14, 2004 | 11:04 AM
bad2000ss's Avatar
What he said.
My car looked really crooked after the 12-bolt install. I jacked the car up, put jack stands under the frame and let the rear hang. I think one or both of the springs might have been out of shape. It make a little clunk noise when I removed the jack from under the pumpkin, and straitened itself out.
Old Jun 14, 2004 | 06:23 PM
SUX2BU's Avatar
Yeah i just re installed my 8.8 so i'll check that out. it was like this before but never this bad.
Old Jun 15, 2004 | 02:03 PM
Colonel's Avatar
If you really twisted something then your doors would fit funny and your windows/T-tops would probably leak.
Old Jun 15, 2004 | 10:32 PM
SUX2BU's Avatar
door lines are fine so maybe it is just the springs
Old Jun 23, 2004 | 03:13 AM
Spooln's Avatar
Default Sprung Out
There is a certain way to install your springs. If you don't install them correctly your car's suspension will react choppy also the car will not look rite. Remember you also have those rubber spring cups up in there to.
