Drag Racing Tech
Anti roll bar needed?
Old Feb 29, 2016 | 09:08 AM
TXCatfish's Avatar
Default Anti roll bar needed?
Finally got some testing in this weekend with the new trans, converter and all new shocks. First thing I noticed the car spun a little and it's not leaving square. Here is a still shot from a video.
It's mostly stock suspension except strange da shocks (front), comp engineering shocks (rear) and midwest chassis adjustable torque arm.
I was told anti-roll would fix this issue and also read it's not needed that my suspension is not setup correctly.
Any suggestions would be appreciated.
Old Feb 29, 2016 | 09:23 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Jamie, Call Madman 281-432-0393. Tell him I sent ya.
Old Feb 29, 2016 | 09:28 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
The MWC anti-roll will help you for sure, it is a proven working combo. I would strongly suggest a set of rear coil-overs too but we can work with what you have.
Give us a call, you know we will get you taken care of!
Old Feb 29, 2016 | 09:32 AM
TXCatfish's Avatar
Great, thank you!
Thanks.
Old Feb 29, 2016 | 11:54 AM
RENE'S RAGE's Avatar
Yeah, MWC!
Old Feb 29, 2016 | 02:54 PM
TXCatfish's Avatar
Originally Posted by RENE'S RAGE
Yeah, MWC!
Do you run the bolt-in or weld type anti roll bar?
Old Feb 29, 2016 | 03:33 PM
MidwestChassis's Avatar
If I remember right he uses the weld in arb.
Old Mar 1, 2016 | 07:36 AM
I run the bolt-in type.
I think the bracket is alittle bigger, but in bolts in the stock location, no guessing. You can weld it also, if you like.
Old Mar 1, 2016 | 08:12 AM
TXCatfish's Avatar
Okay thanks!
Old Mar 1, 2016 | 04:27 PM
93camaro_zzz's Avatar
I went low 1.3 sixty foots on stock rear shocks. Front shocks are the most important, I couldnt get past 1.8 sixty foots without them. However, a good drag bar is going to help you out a lot. MWC is a good unit, as well as Spohn. I have the Spohn weld-on on my car.
Old Mar 1, 2016 | 05:24 PM
TXCatfish's Avatar
I went 1.58 with stock front shocks. Now have mwc torque arm, strange da front shocks and comp engineering rear shocks and I go 1.49 60'. But doesn't leave square at all and it does spin just a tad.
I'm leaning towards the mwc roll bar.
Old Mar 1, 2016 | 05:34 PM
Get some '93-'97 V6 springs for the rear.
Old Mar 1, 2016 | 05:50 PM
TXCatfish's Avatar
And I run a different trans/converter. So I made quite a few changes to go from 1.58 to 1.49.
I think for now I'm gonna do the arb and then once I get a break between races I may try different springs. Thanks.
Old Mar 1, 2016 | 09:58 PM
RobsZ28's Avatar
I have a MWC anti roll bar on by car, made a huge difference. My car use to twist on launches, actually cut up a passenger rear tire once because body got into the tire. Now it leaves straight, square and even.
Old Mar 2, 2016 | 01:08 AM
Blown06's Avatar
8 Second Truck Club
That should be the end of this thread. If you have an F-body, and want it to 60', you call him.
Old Mar 2, 2016 | 08:04 AM
TXCatfish's Avatar
I called him yesterday. If I weld it in he definitely has the hook up. Haven't ruled him out.
Old Mar 2, 2016 | 12:13 PM
01ssreda4's Avatar
Im running the weld in mwc. Works good. See sig.
