Drag Racing Tech
Battery Relocation Fuse
Old Sep 30, 2012 | 11:47 AM
RENE'S RAGE's Avatar
Default Battery Relocation Fuse
Relocating battery to back.
I remember, that you need a 250 amp fuse.
The question is, do you fuse the ground side or hot side at the battery.
Also were do you get the fuse and fuse holder at.
Old Sep 30, 2012 | 09:27 PM
trans2000am's Avatar
hot side, i picked up a fuse holder for a amp kit havent had any issues
Old Sep 30, 2012 | 11:47 PM
StraightTimeStirrups's Avatar
Can you guys post photos of your set ups and how did you route the cables?
Joe
Old Oct 1, 2012 | 12:28 AM
01ssreda4's Avatar
The fuse will function properly on either side of the battery. Common practice in general is to fuse on the + side for all circuits, and I don't know/care what the rulebooks say pertaining to racing. They might have a rule regarding it.
Old Oct 2, 2012 | 05:30 PM
I've always in the past fused the hot side. Then I saw a wiring diagram with the negative side fused. Now thinking about, being a DC circuit, that might be the best place for it. You have to have a ground from the battery or nothing on the car will work.
I may be wrong. Like always. LOL.
Old Oct 2, 2012 | 05:42 PM
666ws6's Avatar
I used a ANL type 200 Amp fuse. Google it, they are cheap and all over. Or go to your local stereo store.
Old Oct 2, 2012 | 07:27 PM
Doug G's Avatar
I used a ford solenoid in trunk next to battery...12" of wire from + side to switch, 16" of wire to noid, 13' or so to starter.
This way, using the solenoid, the wire to the starter in only hot during cranking.
Old Oct 2, 2012 | 07:29 PM
lsxtreme17268's Avatar
I was reading something today about doing this. sounds like a good idea to me
Old Oct 2, 2012 | 10:24 PM
ramairws6's Avatar
Nope, you are right on the money..... Neg. side for the win
Old Oct 3, 2012 | 07:47 AM
Jeff Smith's Avatar
what size the battery to starter you use? 4awg? How work to 250 amp fuse attach to 4 awg? Just curious.
Old Oct 3, 2012 | 07:48 AM
Jeff Smith's Avatar
what about alt goes to starter or battery in charging feed, use fuse?
Old Oct 3, 2012 | 08:56 AM
ramairws6's Avatar
Fuse the ground/negative side and be done
Old Oct 3, 2012 | 05:20 PM
Doug G's Avatar
I used welding cable (O-guage)
I used 8guage to battery.
IF you plan to hit the dragstrip with the battery in the trunk; the disconnect is a must.
IF you ran the alt. wire to the starter, the switch won't work.
Old Apr 2, 2013 | 04:02 PM
Sleeper S10's Avatar
What size fuse or circuit breaker would you suggest for a 402?
I popped two 150 amp fuses cranking the starter to prime motor before first start.
Old Apr 4, 2013 | 01:47 PM
Wow, blowing a 150 amp fuse just to prime the motor.
Are the plugs in or out, when trying to prime the motor?
How long does it take to blow the fuse? Instancetly or does it turn over a
few times?
Is the starter good?
Old Apr 5, 2013 | 06:03 AM
The plugs are in and coils disconnected. Starter is new.
I put in a 200 amp fuse and that worked.
Old Apr 5, 2013 | 07:56 AM
I would pull the plugs before priming.
Pm sent.
Old Apr 6, 2013 | 08:07 AM
Thanks I didn't know that. It would make sense.
Old Feb 29, 2016 | 04:06 PM
Patsy57's Avatar
Bringing this back one last time. Where are you guys within in the fuse box?
Old Feb 29, 2016 | 07:28 PM
WOW! Almost 3 years old!
What was your question again?
