Drag Setup; Strano/Koni vs Stock
I have a set of 275/50/15 555r and skinnies now. Would it be more beneficial to go back with a stock setup (I have a stock Z28 I can swap the full suspension with)
I also have a set of V6 rear and an abundance of V6 Camaro in the junkyard of those V6 front springs will work out better.
Side question, i know lowered rides aren't optimal for the strip... any way to prevent my car from looking like its competing against Grave Digger at the Monster Jam?
Future setup is LQ9/LS3 top end.
Thanks.
The Camaro's front shock has 116K miles, not too worn out. Should I keep the front V8 or go with a V6 spring, I have 93-97 (95 in/lb) for the rear that I will probably pair up with C/E 3 way
