When exactly is cage required
And I don't mean good luck to you. Good Luck to the other People racing you. Your car will be all over the track, with less and less control as your chassis loosens up, from launching the car. The old, one wheel hang. Why would you come on here, and ask for advice, then make the comments you have. Trying, and I repeat TRYING, to act like Billy Bad Azz. And putting everyone around you at risk. Be Smart. Get the right safety equipment. The tough guy roll, is pretty stale. No one is impressed. Sorry for the rant Fellas. But WTF
So, we've established that not lifting on passes that should be aborted nets 2 results. Both negative. So............guys get your head out of your *** and be safe.
Again, not trying to slam you, but you may find your prospective changes either suddenly or gradually. Good luck to you.
Also, if this is the fastest car you've had, be cautious. Trap speed isn't the end all be all and some things you can't control such as the guy ahead of you spraying coolant or trans fluid at the traps.
The common thread always seems to be unlike the street at some point the track is going to hook and if your crooked and wheeling it like you can on the street its a big shock when it does finally find sticky track , it will go whichever way its pointed as soon as that happens which is into a guardrail or worse.
Moral to the story if its still spinning a couple hundred feet out back off and try again on another pass don't try to ride it out like you can on the street it might bite you in the ***.
I have seen many people want to know et without caging , usually make a half track pass or 2 to get the launch sorted then make the pass that gets you kicked out lol
Good luck let us know how it works out .
It's your choice to go without a cage but it's also the tracks choice to ban you and they likely will.
