Drag Racing Tech
need to gain a tenth
Old Jun 17, 2004 | 04:08 PM
Fast Eddie's 02 T/A vert.'s Avatar
Default need to gain a tenth
I would like to reduce my race weight rather then do another mod,I'm looking for a cheap mod.
I need opinions.Would it help to remove my(metal)hood,back seat,sway bar,and 1/4 tank of gas vs half tank.Or can someone tell me of an inexspensive mod I can do.
My mods are in my sig.
Thank you
Old Jun 17, 2004 | 04:23 PM
blkZ28spt's Avatar
!back seat, you can always put it back in rather easily. Mine was like 22 pounds. Spare tire/jack was ~38 lbs. Gas is heavy as well.......
Old Jun 17, 2004 | 04:45 PM
NJSPDER's Avatar
anotehr freebie is to jack up you front tire pressure at the track. take whatever the max recomended cold pressure is on teh sidewall and add 10psi to it whiel you are running. makes it easier for the car to get rolling and rolls easier down track for a little mph gain.
later
tim
Old Jun 17, 2004 | 04:51 PM
The Juggernaut's Avatar
run it low on gas (gas is 7 # per gallon)
Take all the junk out of the car.
pull the spare/jack and back seats.
Inflate the front tires to 50psi
pull the front sway bar or disconnect the ends
run the washer fluid low or out
there is your tenth if not more
Old Jun 17, 2004 | 06:08 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
I am with
Coach
Old Jun 18, 2004 | 11:14 AM
Thank you for the help..all who replied.No one has shed any light on the idea of removing my metal hood.I wish the coach would tell me what he thinks about removing my hood.
Old Jun 18, 2004 | 11:30 AM
Are ya talking about just taking it off at the track?
Coach
Old Jun 18, 2004 | 12:27 PM
Yes Coach,I was thinking about removing it at the track before I race.I guess I'm concerned about aerodynamics vs weight/heat.I also noticed some of the racers are removing their hoods on the old school cars.
Old Jun 18, 2004 | 12:58 PM
It will help ya with weight reduction but your Hot Rod will look like Sh**t!
Can't hurt anything, try it out and post up your results.
Coach
Old Jun 18, 2004 | 02:14 PM
soliari's Avatar
I usually run 30 psi in the stock front tires ... how much will going to 50 psi (cold) help??
Old Jun 18, 2004 | 03:28 PM
bad2000ss's Avatar
It is probably ok to go 5lbs over the recommended maximum on the tire. Anything more would be pushing the envelope a little too far, and you might be compromising your safetly.
Old Jun 18, 2004 | 04:30 PM
soliari's Avatar
ok, but how much will it help the ET/MPH??
Old Jun 18, 2004 | 06:08 PM
bad2000ss's Avatar
There probably wouldn't be any kind of significant difference, unless of course your front tires were at 5psi and about ready to fall off the rim. If you filled your tires to the maximum pressure suggested by the manufacture, you probably wouldn't see any better times filling the tires 15-20psi over.
Old Jun 18, 2004 | 07:20 PM
soliari's Avatar
thanks. that's what i thought, but I was holding out hope
