Drag Racing Tech
Where did u put your line lock button
Old Jun 18, 2016 | 10:13 PM
mngoos's Avatar
Default Where did u put your line lock button
I have an sjm line lock and looking for options on where to mount push button. I was going to hook it up to the horn but having issues with finding how to do it, so looking for other options
Old Jun 18, 2016 | 10:35 PM
jrpimp00's Avatar
I have the SJM on as well. I used a switch plate from emblem pros. Mounted the arm button on top left and the momentary button on bottom left. Played with it today and no issues for me mounting it there.
http://emblempros.com/inc/sdetail/2034/961
Old Jun 19, 2016 | 02:32 AM
RobsZ28's Avatar
Green button on the steering wheel.
Old Jun 26, 2016 | 09:32 PM
Kent1's Avatar
I put the line lock button in my ash tray!!
Old Jun 28, 2016 | 05:00 PM
RENE'S RAGE's Avatar
That's here I put my t-brake.
LL on toggle switch in my switch panel.
Switch panel is here hvac controls were.
Old Jun 28, 2016 | 07:32 PM
Taxman20's Avatar
I have the same steering wheel as Robs in the picture. Right side is trans-brake, left side is the bump button and the inner hole in the left side is the line lock. I have a toggle switch that activates the rpm limiter for the burnout. So I can release the line lock to start rolling and the rpm will stay so I don't have to worry about it.
Old Jun 29, 2016 | 12:39 AM
Heyfred's Avatar
Old Jun 30, 2016 | 11:25 PM
Rick01SS's Avatar
I made a switch plate for my ashtray out of 1/8" plexiglass. Cut the bottom of the ashtray off and super glued it to the top of the ashtray. I will either paint it or make one out of a 3mm carbon sheet.
Old Jul 1, 2016 | 05:18 PM
Kevin97ss's Avatar
Cruise control "set" button...Cruise on/off switch to enable/disable. Used a small amount of Brake Kleen on a paper towel to remove the cruise control lettering.
Old Jul 1, 2016 | 06:09 PM
Taxman20's Avatar
Here is the picture of mine finally. Mine is the inside left button.
