Drag Racing Tech
Which MT Drag radial
Old Aug 12, 2016 | 01:21 AM
Heavy H.P.'s Avatar
They look good man real good. Are those front 8ply?
Really want to see what people are saying about them holding up on the street. I may just get some SS's for my car.
Old Aug 12, 2016 | 07:16 AM
a05c's Avatar
Be sure to check them for leaks. We had 2 sets of Radial Pro's that the bead was under .600" thick.
If they don't hold air very well, like 1-3 (or more) psi over an hour.. soap the bead and check them for leaks.
Had problems with them not sealing around the beadlock rings. If they do leak, call MT. They will take care of the problem.
Old Aug 12, 2016 | 08:53 AM
Guitar's Avatar
The only 8 ply ones are the part number 1573 MTs which is what I run. Bias so they are light and they do well on the street, don't expect them to last a super long time though obviously.
Old Aug 12, 2016 | 10:01 AM
Heavy H.P.'s Avatar
I wish they made the 8ply in a white letter tire for that look but hey. I need to see if I can run those with the SS's out back.
Old Aug 13, 2016 | 04:40 PM
BOLO's Avatar
As mentioned, you can probably run them on the street, but I don't think they will last. Their Sportsman series is more suited for street diving, I believe.
Old Aug 14, 2016 | 06:57 AM
Doug G's Avatar
Let us know how you like them and how the worked
Old Sep 1, 2016 | 01:11 PM
Mike Blanco's Avatar
Where do you guys typically buy your tires?
Old Sep 1, 2016 | 01:32 PM
BOLO's Avatar
I bought mine from Jegs since they had it in stock.
Old Sep 2, 2016 | 06:49 AM
a05c's Avatar
We usually pick ours up from the Mickey Thompson Trailer at various races.
Old Sep 2, 2016 | 11:13 AM
98_WS6_M6's Avatar
Sometimes local shops will order the for you and mount them for free so I always check that first. Speed Inc usually has decent pricing on tires too
Old Sep 2, 2016 | 01:32 PM
joeZ96's Avatar
I usually pick up tires from Speed Inc. but last time I was at my local Discount Tire to get tires mounted, the manager told me he can order and get a hold of pretty much anything I want.
