Drag Racing Tech
BCU with out ECU question..
Old Jun 29, 2016 | 11:37 PM
nxfirebird's Avatar
Default BCU with out ECU question..
it might be a dumb question but I have got conflicting advise on this one. simple question - on a 98 v6 Camaro that's been turned in to a race car, i'm using all Holley stuff not using the factory ECU and dash. I want the power windows, locks, and lights to work, do I have to just rewire the whole car direct or will the BCU still function enough to do these things?
thanks!
Old Jun 30, 2016 | 12:35 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
You can just take the ecu and engine harness out and everything else will still function separately. My car was done this way and everything worked without it. I just took it all out to save weight and get rid of unneeded mess.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jun 30, 2016 | 11:07 PM
nxfirebird's Avatar
that's what I wanted to hear! thanks!
Old Jul 3, 2016 | 01:57 AM
SteenH's Avatar
Is there anything other than an ignition source needed when removing the whole PCM and switching to like a stand alone? I apologize if that doesn't make sense. I'd like to switch to a standalone, and more than likely will if it's literally a rip it out situation. Thanks in advance
Old Jul 5, 2016 | 01:34 PM
BMR Sales2's Avatar
I really didn't have to run any other wiring. My battery is in the back so I had to run my main hot wire to the starter, then tapped a 4ga wire from there up to the main power feed terminal of the fuse box. Everything still worked in the car without a pcm or engine harness
__________________
Glenn ***
Sales Tech
813.986.9302
Old Jul 7, 2016 | 07:42 PM
JL ws-6's Avatar
Race your car!
I used a pair of DPDT momentary switches to open/close my windows, no issues at all. Lights I have them all being wired when the car gets wired, I'm using the running lights to signal the ign. is powered, center brake light to signal transbrake is on, reverse lights for when nitrous stages come on, although these will be on a switch to break ground on them when I want to for grudge stuff.
interior light I'm putting on a switch, no headlights in my t/a anymore but there will be a pair of extremely bright LED fog lights that will serve as headlights. Brake lights will work and are triggered off a pressure switch on the rear brake line.
Hope that helps.
