Can't get M6 to hook-up at track
With my stock redials I was only pulling 2.1 60's if you needed a comparison.
<strong>Are you using stock radials, if so you might want to get a set of drag radials that will help a bunch. how long are you doing your burnout?
With my stock redials I was only pulling 2.1 60's if you needed a comparison.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Have stock radials, lowered to 18psi. Best 60' was 2.22. Did about a 5 second burnout.
Here is what I do.Lower tire pressure to 25lbs.
Do a good burnout.I pop the clutch at 4500 rpm and mash the gas and hold it at 5000-5500rpm till it really smokes up.
Roll out of the burnout to the line.Stage,Bring rpm up to 3000rpm and on last yellow let clutch out fairly fast and floor it.This gives me consistant 1.93-2.0 60's.Also shift like you stole it <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>With a little practice you can get good 60's.
Roll out of the burnout to the line.Stage,Bring rpm up to 3000rpm and on last yellow let clutch out fairly fast and floor it.This gives me consistant 1.93-2.0 60's.Also shift like you stole it <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">right on man preach the truth! that is exactly how i do it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
On street tires stay out of the water and dont do a large burn out. I normaly give the tires a small low speed spin just to get all crap off them.
Also with regular radials, lowering below 25psi or so normaly hurts your traction.
I cut 2.0's all day on "NANKANG" brand radials. Believe me, you havent heard of that brand for a reason...they suck!
-Doug
Good luck to you.
Bob
No more than 2000-2200 at launch should net you a low 2.0. I didn't find any less than 25 lbs in my f1's helped, cause the tires would "cup" at low pressure.
