Drag Racing Tech
Help! Dart SHP LS Next block?
Old Mar 21, 2017 | 02:22 PM
TTur1996's Avatar
If you want the LS Next to be really strong. Get the Next 2 upgrade. 1/2inch head and main studs and the material in the main area is increased so you can use either the standard , or big block main journals. Bigger Billet caps too.
Old Mar 16, 2018 | 11:00 AM
Racesloth's Avatar
Wake up this thread -
Now LS Next SHP Pro is cast out of the same higher quality iron as the LS Next - should be much better for higher HP builds and half mile/mile effort cars due to better oiling...
