Help! Dart SHP LS Next block?
How do you intend to use it?
If I were to build an lsx motor tomorrow the tall deck version of the dart ls next would be the way I would go, no question.
Also I had a lot of questions on the center counter weighted crank offering but was also told it was not meant for high hp applications but could not get an answer why.
I ended up buying a 427 LSX due to my frustrations with their tech service honestly.
If I had to build an ls style motor tomorrow, tall deck ls-next block, and a ccw crank would be the first 2 things on the list, allpro casting would be next on the list. But that's me.
If going beyond 1500 horsepower, we recommend our LS NEXT block. We believe it is the strongest LS block made.
The SHP platform means that it is a direct high performance replacement for factory blocks.
The LS NEXT block can be used as a direct replacement in most applications with the use of the oil pan spacer/adapter. This spacer now even has the provisions for the A/C compressor mount and the extra power steering bolt hole.
Cases like the CTSV where they have a low mount alternator may prefer the SHP block as the oil port is directly behind the alternator on those low mount alternator applications.
I am very sorry to hear that you did not get the information you needed from us to make your decision. Please let me know next time you need technical information. I want to assure you have all the information you need to make the best choice for you.
I understand a lakes thoughts on just going BBC though, as I did that myself, options are just too plentiful, and I did the same myself, but I committed to this before the ls next amd out.
Don't worry though there's a big M between my frame rails, and when I eventually upgrade that Pascal Lecompte will be sourcing the alum 10.4 block and 11 degree big chief castings from you in sure ;-)
Anyways I'm looking for 1k rwhp with a procharger and it's gonna get driven most days in Florida and will certainly spend a lot of time in traffic
This realistic to expect the block to handle this? Car is used for roll racing
