Please explain ET and MPH
Some people look at my MPH and can tell right away that I am having traction problems off the line, how?
My best was a 12.49 @ 114
Some say I should be a low 12 with a 114 MPH trap speed. I do have a M6 and running Nitto drag radials at 20 PSI. I am still practicing the launches though.
Is there like a rule of thumb guideline some where?
Example: If you got 108 MPH you should be xx.x ET or if you have a 12.8 you should have xxx.xx MPH
R/T - .780
60' - 2.064
330 - 5.428
1/8 - 8.184
MPH - 90.54
1000 - 10.519
1/4 - 12.490
MPH - 114.80
<small>[ April 10, 2002, 12:21 PM: Message edited by: 2000 Camaro SS ]</small>
Then, if it's real obvious, like 12.2 @ 122 mph, it's a no brainer. 122 mph is good for low low 11s in an M6 LS1. In an A4 it should definitely be good for high 10s. I don't know if the same rules hold up for other types of cars? I'm sure it's close to the same though.
Derrick
MPH= how much power you make
I ran 11.1@121mph last year at 3700 raceweight, that is about right. That is with a 1.53 60, and on a ET Street.
Now with a drag radial, and an M6, I'd say it would have been more like a 11.9@124mph on like a 1.8 60 ft.
I went 11.75@114mph with an A4 and heads and cam, on a 1.57 60. on DR's I went 12.1 on a 1.7 rolling out really easy.
John
