weight reduction mods without gutting interior
as far as suspension i have LCAs and relocations, plus subframe connectors now i want to work on weight reduction but i do not want it to look like a drag car are there many hidden weight reductions i can do? i have a/c an i definitely want to keep that also leather interior an love it Do you really need carpet? It's just a dust trap. Think of your house, tiled or wood flooring versus carpet (respiratory death). I personally take the race car style steel floor and near 40 lbs gone anyday of the week.
There's a LOT on these cars you can do without and get used to the 3000 lbs of fast goodness.
Who needs ABS? are you an old lady driving in snow that doesn't know how to drive? then you need ABS. I don't need ABS.
Lightweight wheels and front suspension. Begin with wheels, then lower control arms.
Tubular front k-member with tubular A-Arms, lightweight wheels, FAB 9in from MWC with all lightweight components, and fiberglass hood, carbon fiber driveshaft
Then tubular front bumper support, ABS delete, take carpet out and take the sound pad off and re install, go to an exhaust that stops at the rear end, take the heat shields off the back of car once you put the new exhaust on, go SD tune, do wire re work for what you taken out, smaller battery, relocate fuse blocks into behind the dash during rewiring, cut out door bars inside the doors,
Those are just to name a few and there is ALOT more just depends on your budget and how crazy you want to get with it.
Good post SCott5, After you lighten one of these cars you realize why everyone has a Foxbody Mustang
I also forgot to add light weight brakes from strange or aerospace, light weight spindles, take fenders off and cut out that metal under those and then reinstall. Also be aware that down aftermarket parts do add weight but are needed, torque arm for example.
As said there's lots of weight that can go.
I do t like the no carpet look I think it ruins the street car appearance, but ozite is a god alternative. I've installed it in about 50 cars and it's a 30 to 35 lb sack ga without ruining the look.
I out it in my 25.3 chassis race car. Believe me I'm after weight in it... But not enough to worry about the 5 lbs of ozite that's in it.
Feather Carbon
