Pics of hoosier 26x 10 15 &actual size?
Anybody have any pics of 26x10x15 hoosier bias plys? I'm stuck between those and m&h 27x10 but I'm worried the 27's run big and won't fit. What are the actual size of the hoosier 26's I bought a set of 28's and they measured a rad over 29" and had to send them back. Any pics would help out
In my opinion, you can't measure tire height with a yardstick. You can't use those number as actual, the tire bulges in the center, etc. If they say they're 28's, they're 28's, not 29's. Though some do run a little bigger than others.
Now, you can run a tape measure around the circumference to compare two slicks for compatibility, or compare two different brands side to side.
M/T's drag radials tend to run big, but the M&H drag radials run about normal.
Al
Al
