Drag Racing Tech
PSJ, How'd you do?
Old Jun 20, 2004 | 01:58 PM
RUQWIKR's Avatar
Default PSJ, How'd you do?
PSJ, sorry, but I never got a chance to see a run of yours. How'd you do and what's next? Take care and thanks for all of your guys's time to put together the event.
Old Jun 20, 2004 | 02:12 PM
BIGBOS's Avatar
10.3@135 with a 1.5 60' he tripped the beams early on that pass
Its got plenty more in it
Old Jun 20, 2004 | 02:23 PM
The Juggernaut's Avatar
^ PSJ official spokesman/ PR guy.
Old Jun 20, 2004 | 03:17 PM
CHRISPY's Avatar
good job PSJ 9s are in the bag
Old Jun 20, 2004 | 04:04 PM
BIGBOS's Avatar
Your funny Sean
Old Jun 21, 2004 | 12:47 PM
V6 Bird's Avatar
9s are in the bag???? They why didnt he do it at the event. Im so glad i didnt go to race. My cam only car would have busted his ***!
Mike
Old Jun 21, 2004 | 12:56 PM
Cmarsh93z's Avatar
John, seems like you are finally getting your act together!!! Car is really starting to fly.....9's should be around the corner. I had my doubts when you used to switch shops on a weekly basis, and post up all your crazy posts. Now its seems that everyones ideas are really coming together for some fast, LOW 10 SEC PASSES! Not bad for a few years work!!! I thought those NA 346's where fast with multiple 10.20's...bust then i see this YSTrimed 346 running 135, and I just gotta say "WOW"
Chris
Old Jun 21, 2004 | 01:01 PM
Cmarsh93z's Avatar
Mike
Mike, how can you be so negative? Its hard to take the advice of 100's of people off the net, cram all those good ideas into 1 car, take it to 20 shops, then make the thing run good! I think Low 10's are really good......think how hard it was to go low 10's back in the 1920's. Exactly....they didn't, and PSJ makes it looks so easy now!
135 mph....SLOW THAT THING DOWN JOHN!!! 9's are just around the corner!!!! Not that corner, the next one
Good job
Chris
Old Jun 21, 2004 | 01:34 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
We were tuning the FAST standalone on the track and I made a total of 3 passes and the first one was off idle and I did not run out 3rd since it phat-popped a few times.
Second pass it went 10.38 on a 1.65, footed it to 2000 and rolled out and ran it out but lost the belt at 1000 mark and i coasted to a 129.
Third pass we added fuel and I went off the 'brake but broke the beams and went 10.33@135.97 but had I not broke the beams the car might have gone 9.99' or better.
Mike Hutto, I love you. I helped work on Hacker's car in 1999 and it went 10.81, and then Dave Purlee and Sean Freese were inspired and went 10.5 and 10.3 respectively, and now you are doing it to. Technically I am your daddy.
Old Jun 21, 2004 | 03:38 PM
Y2K_WS6_T/A's Avatar
Haha.....Mike you gonna respond to that?
Old Jun 21, 2004 | 03:57 PM
BIGBOS's Avatar
HAHA, that is funny
Old Jun 23, 2004 | 06:49 PM
Colonel's Avatar
Why in the hell would anyone think that a car of this caliber should show it's full potential on THE FIRST FREAKIN' TRIP TO THE TRACK?!? That is beyond me. Some of you folks are kind of
9s will be NO problem with the kind of power John's car is laying down. Talk now while you still can.
$1000 says John's car runs 9s this year. Any takers? Heck make it $10,000....or $10, I don't care.
Old Jun 23, 2004 | 07:57 PM
FEAR THE LS1's Avatar
For what its worth...The first time at the track with my new motor I couldn't run better than a 10.7x I now have about 12 passes on my car and am running 10.2x's The car still needs more tuning and will get faster with each pass.
The fact that PSJ came out and went 10.3x's on his shake down runs only means his car is going to be sick when its fully tuned.
Lee
Old Jun 24, 2004 | 09:12 AM
GIZMO's Avatar
Mike
The mph should tell you a lot about the potential of Johns car.
Daren
Old Jun 24, 2004 | 09:26 AM
gator's 99TA's Avatar
yup, i agree with teh others here. laugh while you can, john has the potential and is setup to fly. shakedown passes are never pretty.
Old Jun 24, 2004 | 10:07 AM
LS1Tech Co-Founder
After we broke the oil fitting, the car sat for most of NvsS. Later we found out a friend had an extra (Vortech) fitting, so my friend Intmd8 used an easy-out and then installed the new fitting. He also clearanced the body where it hit.
Pass #1 was that easy 10.83. We had the FAST tuned with 20 degrees of timing. We decided I would shift at 6500. I did all that but it popped twice after the 2-3 shift so I let off. We did not get a FAST log it was my fault.
Pass #2 was a 10.38 on a 1.65 with 129mph, but lost the belt maybe at the 1000 mark. Car nosed over bigtime. Once I got on the return road I figured out I had lost the belt. We added 2 degrees of timing for a grand total of 22. FAST log did not work.
Pass #3, was a 10.33 @ 135.97 on a 1.58. As it turns out, I did not break the beams but I launched like off idle again. This was the first time I had ever used a 'brake. That's why the car went 105mph in the 1/8th but 136 on the big end. Car has no first gear to speak of since I did not build any boost. Got a log this time. We had added fuel for this run and we added too much. I had 10.5:1 AF @ WOT.
Plan is to:
-Take 10% of the fuel out of the MAP
-Eventually try to add in 2, maybe up to 4 more degrees of timing at WOT.
-Look at whether the belt is slipping.
-Use the 'brake for all passes
-Loosen front shocks from tight to loose - I had them at 10 tight for the first few passes
Car leaves straight as an arrow and I think that Spohn drag sway bar gets the nod for that.
We'll see what it does Friday nite.
Old Jun 24, 2004 | 10:29 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Congrats PSJ.
It feels good to finally run 10's don't ya think?
I say PSJ will be in the 9's before the Thunder Shootout race. Maybe even this weekend.
Good luck this weekend.
Coach
Old Jun 24, 2004 | 10:43 AM
LS1Tech Co-Founder
Thanks Coach.
Should I go hit the showers or run around the field some more?
Old Jun 24, 2004 | 10:50 AM
Big Mike's Avatar
I think once John gets the "bugs" straightened out, the car will go 9's on a bad day!
Old Jun 24, 2004 | 10:54 AM
LS1Tech Co-Founder
Must catch Big Mike ack ack.
