Drag Racing Tech
MSD 2 step. What to start at?
Old Sep 26, 2016 | 06:58 PM
liketowork's Avatar
Default MSD 2 step. What to start at?
What should I set my MSD 2 step at for starters. 228R can 3200 stall. Thanks
Old Sep 27, 2016 | 10:10 AM
93camaro_zzz's Avatar
Is this a 4L60 car? Without much information, and just assuming you don't have a transbrake, I would set the 2 step about 400 rpm below the converter flash point. As a start. Then just start moving it up 100rpm at a time, until it starts pushing the car through the brakes, and you can't hold the car still anymore.
Old Sep 27, 2016 | 10:54 AM
liketowork's Avatar
Thanks. And yes. It's a 4L60e. (Red Eagle clutches, PowerPack, Raybestos pro Siri's band,shift kit) The converter is a SS3200 yank
Old Sep 28, 2016 | 04:45 AM
Doug G's Avatar
I found I get my best 60's flashing my converter off the line Vs. trying to stall it.
No TB.
Old Sep 28, 2016 | 04:00 PM
RENE'S RAGE's Avatar
I never understood a 2-step without a tb.
Maybe I'm missing something.
Old Sep 28, 2016 | 05:26 PM
tug686spd's Avatar
Same principle as as trans brake, just floor it and let off the button when its go time. The limiting factor without a trans brake is the actual brakes though. If you know your car starts pushing through the brakes at 2300 then set the 2 step at 2100 and floor it. The bad part without a trans brake and trying to stall up the converter is it extends your suspension while coming up on the stall taking away that movement on the launch. None of 4th gens worked very good trying to leave up on the stall, they all worked they're best flashing it up from about 1500 all 4k plus stalls.
Old Sep 29, 2016 | 09:47 AM
I always had better luck just flashing my 4l60 with a 3800 stall.
Old Sep 29, 2016 | 10:10 AM
I can understand it if the car is turboed, but yeah, I agree with the above, if my car was N/A and no Tbrake, then I would just be flashing it off idle.
