Broke something last night at the track
Clutch is a Monster Twin LT-1.
Puzzled as to what it is. Input shaft, I would have heard it break? Slave cylinder gave out?
What do you guys think?
So strange.
Like I said usually a driveline issue will make its presence known pretty abruptly. If there isnt a shifter issue. Put it in a gear and see if the drive shaft spins if thats the case you have a diff issue. If not youre going to have to pull the trans
You said you did the burnout, then staged the car. It had to be in gear and working for you to stage the car. At that point you would have just pushed the clutch in and left it in gear to be ready for the launch. So you were in gear to stage it and you never took it out of gear right? If this is the case, you broke something. During the burnout, when you let off the gas, there is a point where the tires gain grip and usually chirp and makes the car surge forward. You might have cracked the input shaft at that point but not break it completely through, then on the launch it snapped. But since it might have already been near actually broke through, it didn't have the strength to make the car move or break where you could hear it.
Doing some head scratching here for ya.
I guess that's what I get for using a drag radial with a manual.
